Results 1 to 3 of 3
Thread: any idea how to send and receive data between two teensy 3.6 using CAN bus
    Sep 2018
    san francisco
    2
    Hello all,
    i am trying to send messages between two different teensy 3.6 using CAN-bus. or send and receive between CAN0 and CAN1 on one teensy3.6
    if anyone has done anything like this before, their help will be much appreciated.
    9,700
    There are forum threads for CAN - one covers this CANbus Library for Teensy 3.1, 3.2, 3.5 and 3.6 :: https://github.com/pawelsky/FlexCAN_Library
    This is newer WIP from tonton81 - did a quick function test with T4's CAN3 - but it shows CAN2 compatibility too: github.com/tonton81/FlexCAN_T4
    Apr 2019
    141
    You don't need to use can - connect the tx and rx of the teensys together and use serial !
    easy peasy
