Results 1 to 5 of 5
Thread: Anyone done a QP-nano state machine framework with Teensy 3.2?
    Nov 2016
    7
    I've gotten interested in the QP framework to implement a more complex state machine. Reading through the QP lit doesn't suggest it's possible to target a T3.2. https://www.state-machine.com/arduino/ Anyone out there done that and what does it take?
    Germany NRW
    5,679
    Not sure what it is useful for.. I read a bit about it.. I think it's way easier, more flexible and better to write a few line of c (++) - code (and I don't need to license anything or worry about updates and if it still exists in some years)
    Nov 2016
    7
    Thanks. I was just looking for something that looked robust and could grow or handle anything else that came along. I ended up doing pretty much what you suggest with the help of the Automaton Timer Machine and then managed state transitions myself.
    Apr 2019
    114
    Windows is event driven and i have often wondered if a microprocessor could operate this way
    my concern is a kernel/app will end up running to recreate a event driven environment but in fact it is just adding a main loop and hiding it from the programmer
    a arduino does not have multiple threads - so it must have a main loop ?
    9,303
    Windows was event driven before single core Pentiums.
    Arduino basically/literally runs a while(1) from main(). The while(1) just calls loop() over and over - and to handle serialEvent() processing also calls yield() in each loop as well..
