Results 1 to 9 of 9
Thread: L.E.D. Staff with ws2812
    Jul 2019
    5
    I would like to work on an LED staff. I recently purchased a teensy 3.2 And I am working with six strips of 110 leds each- the strips are ws2812- I have tinkered a bit and I have no issues getting them powered on and even A test pattern going with the fast led library- But my biggest brick wall I am running into Is the coding part and bringing everything together.
    I am wondering where I can find some help or if anyone is available to assist or provide guidance so that I can get to the final product?
    My original motivation for this Was seeing a project on this site for an led staff But there doesnít seem to be much out there in terms of getting from point A to point B. Appreciate any assistance And I have a link to the original idea below
    https://www.pjrc.com/led-staff-with-1500-pixels/
    Senior Member crees's Avatar
    Dec 2016
    Utah
    194
    See post 9 from this link. This should give you some ideas . Perhaps put a sensor or switch to tigger effects.
    https://forum.pjrc.com/threads/54549...+button+ws2812
    Jul 2019
    5
    thanks so much crees- I am giving this a try now to see what I can come up with-
    one thing I am confused about is, how could I modify this to run on 6 led strips(using a data pin for each strip of 110 leds) So I would be using a total of 6 data pins
    Jul 2019
    5
    currently, trying to setup as is but I am seeing some issues with the button library and teensy 3.2
    Arduino: 1.8.9 (Mac OS X), TD: 1.46, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz (overclock), Faster, US English"
    In file included from /Users/shawhin/Documents/Arduino/new-test/new-test.ino:8:0:
    /private/var/folders/9d/djg9_8gx3_n84086hbv1fd9w0000gn/T/AppTranslocation/115824EC-6722-4BB4-8808-39629A8453EF/d/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/FastLED/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.008
    # pragma message "FastLED version 3.001.008"
    /Users/shawhin/Documents/Arduino/new-test/new-test.ino: In function 'void setup()':
    /Users/shawhin/Documents/Arduino/new-test/new-test.ino:33:11: error: 'class Button' has no member named 'begin'
    button1.begin();
    /Users/shawhin/Documents/Arduino/new-test/new-test.ino:34:11: error: 'class Button' has no member named 'begin'
    button2.begin();
    /Users/shawhin/Documents/Arduino/new-test/new-test.ino: In function 'void readbutton()':
    /Users/shawhin/Documents/Arduino/new-test/new-test.ino:186:17: error: 'class Button' has no member named 'released'
    if (button1.released()){
    /Users/shawhin/Documents/Arduino/new-test/new-test.ino:190:17: error: 'class Button' has no member named 'released'
    if (button2.released()){
    Error compiling for board Teensy 3.2 / 3.1.
    Jul 2019
    5
    Could this possibly be an issue with the 3.2 board and upgrading to a 3.6 might fix it? Or is this just that Iím using the wrong button library?
    Dec 2016
    Utah
    194
    No I recall it’s a specific library. I don’t have that library on my laptop I am on now. But try a couple different ones to see if they satisfy the compile or modify the existing code to accommodate the button library you have.
    As far as multiple strips look for the parallel functionality of fastLED.
    Jul 2019
    5
    I have tried a few different libraries for some reason I know this is probably really simple but I canít get the right library- Would appreciate any help on this! Thanks So much for the direction thus far
    21,085
    Quote Originally Posted by Shawhin View Post
    Those errors in msg #4 sure look like using the wrong lib, or not including the correct .h file.
    I want to help you, but without seeing your code, it's impossible to say what's wrong or exactly what you should do to fix it. That's why we have the "Forum Rule" in red text. When you show us the complete code you're using, we can do so much more to help you. Don't be shy. Everyone starts as a beginner. We know this and we help every day on this forum, but there little we can do to help solve a specific problem when you keep us in the dark.
    But I can at least point you to a working example. In Arduino, click File > Examples > Teensy > USB_Keyboard > Buttons. That example needs a specific setting in Tools > USB Type. It does compile and work, so if your code is trying to do the same thing (just a guess from what I can see in those errors), maybe that example will help?
    Senior Member mortonkopf's Avatar
    Apr 2013
    London, uk
    911
    for multiple strips, follow crees direction and instantiate fastled for each pin you want: https://github.com/FastLED/FastLED/w...oller-Examples
      FastLED.addLeds<NEOPIXEL, 4>(leds, NUM_LEDS_PER_STRIP);
      FastLED.addLeds<NEOPIXEL, 5>(leds, NUM_LEDS_PER_STRIP);
      FastLED.addLeds<NEOPIXEL, 6>(leds, NUM_LEDS_PER_STRIP);
      FastLED.addLeds<NEOPIXEL, 7>(leds, NUM_LEDS_PER_STRIP);
    the above is where all strips are showing the same array, which is called leds
    for each strip to show something different, that linked page shows you what to do (ie instead of all pointing to leds array, just add in the array you want in place of it.
