Results 1 to 2 of 2
Thread: Simple code results in crash/reboot..
    Jun 2019
    4
    I using an Teensy 3.6 but i dont understand whats going here wrong when i send an command to the teensy.. xD
    String cmd;
    void SerialSend(char c){
      digitalWrite(4,HIGH);
      delay(10);
      Serial.write(c);
      digitalWrite(4,LOW);
      delay(10);
    String SerialRead(){
      cmd = "";
      if (!Serial.available()){return "";}
          Serial.println ("DEBUG - 0");
          while (Serial.available()){
          Serial.println ("DEBUG - 1");
          cmd+=SerialRead();
          Serial.println ("DEBUG - 2");
          digitalWrite(3,HIGH);
          Serial.println ("DEBUG - 3");
          delay(10);
          Serial.println ("DEBUG - 4");
          digitalWrite(3,LOW);
          Serial.println ("DEBUG - 5");
          delay(10);
          Serial.println ("DEBUG - 6");
          return cmd;
    void SendString(String s){
      for (int i = 0;i<=(s.length()-1);i++){
        SerialSend(s[i]);
      Serial.write("\n");
    void SysSetup(){
      digitalWrite(0,HIGH);
      SendString("Dongle V0.1");
    void LedSetup(){
    pinMode(0,OUTPUT);
    pinMode(1,OUTPUT);
    pinMode(2,OUTPUT);
    pinMode(3,OUTPUT);
    pinMode(4,OUTPUT);
    SysSetup();
    LedSetup();
      SendString("Systemtest");
      if (SerialRead() == "TEST"){SendString("TESTSTRING");}
    1,108
          cmd+=SerialRead();
    You are calling the SerialRead function from within itself. That's called recursion and is totally inappropriate here because it will fill up the stack and crash the processor, as you have discovered.
    I think what you really meant was
    Serial.read()
    Pete
