Results 1 to 3 of 3
Thread: Teensy LC HID: Not all keys work on Android
    Jul 2019
    7
    So I am having some success with my project, but I am having trouble using the following keys:
    ENTER
    LEFT_ARROW
    RIGHT_ARROW
    I can type normal text and backspace, and shift works.
    I am confused as to what codes I need to send.
    I found different codes:
    https://github.com/jrowberg/keyglove...hid_keyboard.h
    https://gist.github.com/MightyPork/6...96ee55fdc73db2
    https://www.arduino.cc/reference/en/...oardmodifiers/
    https://source.android.com/devices/i...d-devices.html
    Sometime P and I are printed when I use left and right.
    What code do I need to send for left, right and enter?
    Jul 2019
    7
    So two things: the codes at https://github.com/PaulStoffregen/co...3/keylayouts.h work
    And I had mistakenly limited myself to 8-bit codes. The keys codes are 16 bit, which is confusing because the 6 key slots are 8 bit!!?
    What happens if you want to use a 16 bit code as one of the 6 keys?
    Jul 2019
    7
    So here's my (last?) problem.
    How do I send Ctrl+Esc?
    The example: https://www.pjrc.com/teensy/td_keyboard.html
    Doesn't send esc, which is a two-byte code, so set_key can't be used.
