Submillisecond latency RF link
jvoigts
New member
I need to get a continuous series of values, 2 bytes each, from one teensy to another, wirelessly. The distance is only around ~20cm or so. The constraint is that i'd like this link to have the lowest possible latency.
I am currently using a pair of nRF24L01 modules, and I get about ~400-500us latency, which is a bit too high for my application.
As far as I understand, a lot of this time is due to ramp-up and hadshaking etc.
Is there a simple solution that can get me closer to a 10us latency? It seems like the ramp-up time on the nRF52832 is shorter for instance, but I haven't found any concrete examples for how quickly a very small data packet can be transmitted.
I'd be interested in more low-tech solutions as well, maybe the fact that this is low distance and we're not limited in terms of battery usage means that a more low-tech radio link could be well suited to this application?
That's not silly- the link goes from a rotating part to a stationary one, and there are space constraints that mean I can't easily use a wired protocol over a slip ring.
And I just need a unidirectional link here.
Edit: Forgot to specify, i just need this to transmit the 2 byte value at around 5-10kHz so around 80-160 kbps
I thought about IR light - but oddly enough I this is for an optics application in which i'd like to stay away from both IR and visible light ..
Did something similar using a high-freq version of NFC (manchester NRZ). Totem-poled transistors (push-pull config) used to directly drive the tank circuit to the antenna.
So you will have to roll your own on this, or use an off-the shelf radio.
