SD card openNext does not always work
PAAUX4
I have a micro SD card in a Teensy 3.6. When I use openNext, about half the time it only goes through the first four files but the rest of the time it works. I have not yet tried another SD card.
In the code below, if it only goes through four files, there is about a half second pause between printing the file names and the final newline. This pause is not there if it goes through all the files.
I appreciate the help. Thanks.
#include "SdFat.h"
SdFatSdioEX sd;
File dirFile;
void setup(){
  while (!Serial) {}
  if (!sd.begin()) {
    sd.initErrorHalt();
    Serial.println("sderror");
void loop(){
	if(Serial.available()){
		Serial.read();
		dirFile.open("/", O_READ);
		traverseDirectory(dirFile);
		dirFile.close();
void traverseDirectory (File CFile){
	File pdfile;
	CFile.rewind();//This is probabably the only rewind that is in any way relevant
	pdfile.rewind();
	sd.vwd()->rewind();
	while (pdfile.openNext(&CFile, O_READ)){
		if (pdfile.isHidden()){}
		else {
			char fileName[64] = {0};
			pdfile.getName(fileName, 64);
			Serial.println(fileName);
		pdfile.close();
