Results 1 to 13 of 13
Thread: Teensy 3.6 problem - The chip is very hot
    Aug 2017
    16
    Hello. I have a problem with my teensy 3.6. It is very hot that I can't touch it by hand even though I've just plugged it to USB cable for just a few seconds. The upload code is very simple, (I already tested with the other board, it is ok). The chip which connected to pin D- and D+ pin is very hot.
    Are that normal phenomena?
    If no, what should I do to fix it?
    Thank you very much
    Germany NRW
    5,679
    The chip is defective. This cannot be repaired.
    9,675
    Very hot is a bit relative - though too hot to touch is a bad sign - that is not normal. The Main MCU chip is spec'd to run when 'too hot to touch' - but nothing else should generally unless there is a great deal of 3.3V current in use - and the input voltage is higher that USB voltages the voltage converter chip could get that warm without damage.
    As Frank B cross posted - the T_3.6 has likely suffered damage and is likely broken
    Since it is plugged in to USB - perhaps there is no external power on Vin and the VIN<>VUSB jumper on the bottom is still in place?
    Is/was anything connected to the Teensy? Has it been soldered with pins or other devices?
    There are two pairs of pins on T_3.6 with D+ and D- labels - one pair of pads on the bottom side edge under the device USB connector and one pair of pin holes internally for the USB Host support - so not sure which chip might be referenced - perhaps the ones with traces from the device connector that is 'literally' connected ? The 5V to 3.3V Power converter chip might be the one hot - but it connects to the GND and 5V of the USB connector?
    Aug 2017
    16
    I added 3 pin header a10. A11. Aref. That all i did with this board. But didn't connect to anything. No other power source, but usb.
    9,675
    Quote Originally Posted by thanhvu1990 View Post
    Check for unwanted solder connect to adjacent items there on the top side.
    Mar 2015
    UK
    300
    Bare Bones Sketch
    Let the board cool down. Remove any SD Card or other attachments. Then attach to the USB socket and try running the attached "Bare Bones" sketch on your T3.6.
    It will flash the LED four times quickly on startup, then flash the LED twice every second.
    If you type "A" at the Serial Monitor, after a very short delay, it should print out the current value of "LoopCount" (which increments every second).
    It should run the T3.6 as "cool as a cucumber". If not then there is a fault with the board (or your USB 5 volts supply may be too high - try measure it).
    Make sure the joints you soldered on the board have no bridges.
    //BareBones - Test sketch for Teensy
    //Author: TelephoneBill
    //Date: 15 JUL 2019
    //NOTES: Minimum sketch to test basic operation.
    //definitions
    uint32_t LoopCount;
    byte Byte1;
    //SETUP CODE
      //initialise general hardware
      Serial.begin(9600);                        //setup serial port
      pinMode(13, OUTPUT);                   //pin 13 as digital output
      FlashLED(4);                                //flash four times, just for confident startup
    //MAIN LOOP
      //call KeyInput() routine
      KeyInput();                                 //type "A" to see value of LoopCount
      FlashLED(2);
      LoopCount++;
    //SUBROUTINES
    //Flash LED routine
    void FlashLED(int m) {
      for (int n=0;n<m;n++) {
        digitalWriteFast(13, 1);
        digitalWriteFast(13, 0);
    void KeyInput() {
      //process any keystrokes available
      if (Serial.available()>0) {
        //read the incoming byte
        Byte1 = Serial.read();
        if (Byte1>0x20) {
          switch (Byte1) {
          case 'A':  //type to see value of LoopCount
            //task goes here...
            Serial.print("LoopCount = "); Serial.println(LoopCount);
    Aug 2017
    16
    Quote Originally Posted by TelephoneBill View Post
    //Date: 15 JUL 2019
    //definitions
    uint32_t LoopCount;
    byte Byte1;
    //SETUP CODE
    //MAIN LOOP
      FlashLED(2);
      LoopCount++;
    //SUBROUTINES
    //Flash LED routine
    void KeyInput() {
        if (Byte1>0x20) {
          switch (Byte1) {
            //task goes here...
    It worked, but still very hot. I already check the USB line with other teensy board, it is ok. I already remove a new pin header to make sure, but still the same.
    9,675
    Good that it seems to be functional - a pic with indicator of the heat affected chip would allow understanding beyond - there is a short somewhere - or it was damaged and waiting to fail.
    Mar 2015
    UK
    300
    Seems that Post #2 is the situation.
    Aug 2017
    16
    Yes. I tried to change the chip from other broken board. it run much cooler. Thank you very much
    thank you. check it out too
    By coincidence, I have the same issue with a brand new Teensy 3.2. It came with headers, so all soldering looks good.
    I tested it with the BareBones code, powered from a pc usb, without any hardware attached and the temperature was fine. However, I measured the voltage over the GND and 5V pins, and it was only 2.16V. So there must be something wrong with the board.
    Sep 2019
    1
    I had the very same problem and my Teensy 3.6 was pretty much new. The chip you were talking about is the TPD3S014 which is a Current-Limit Switch and D+/Dľ ESD Protection for USB Host Ports. So if you're not using an extra usb Port (those Pins you were mentioning D+, D-...), this chip is basically useless. I carefully removed it with my soldering iron and the Teensy keeps working like a charm.
    (by the way: this chip wasnt even used on the Teensy 3.5: look at: https://www.pjrc.com/teensy/schematic.html )
