Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 69
Thread: midi controller
    Feb 2018
    154
    midi controller
    I want to build a midi controller with 24 10k pots and 24 digital buttons, I have tried several that didn't work, then I found these two examples. I have tested these codes and each work but they are for only 1 button and 1 pot. My question is, how can I expand each to 24 and then combine them into one sketch?
    [CODE/*
    This is an example of the "Analog" class of the MIDI_controller library.
    Connect a potentiometer to analog pin A0. This will be the MIDI channel volume of channel 1.
    Map it in your DAW or DJ software.
    Written by Pieter P, 08-09-2017
    https://github.com/tttapa/MIDI_controller
    #include <MIDI_Controller.h> // Include the library
    // Create a new instance of the class 'Analog', called 'potentiometer', on pin A0,
    // that sends MIDI messages with controller 7 (channel volume) on channel 1
    Analog potentiometer(A0, MIDI_CC::Channel_Volume, 1);
    void setup() {}
    // Refresh the MIDI controller (check whether the potentiometer's input has changed since last time, if so, send the new value over MIDI)
    MIDI_Controller.refresh();
    }][/CODE]
    This is an example of the "Digital" class of the MIDI_controller library.
    Connect a push buttons to digital pin 2. Connect the other pin of the button to the ground,
    a pull-up resistor is not necessary, because the internal one will be used.
    This button will play MIDI note C4 when pressed.
    Written by tttapa, 08/09/2017
    const uint8_t velocity = 0b1111111; // Maximum velocity (0b1111111 = 0x7F = 127)
    const uint8_t C4 = 60;              // Note number 60 is defined as middle C in the MIDI specification
    // Create a new instance of the class 'Digital', called 'button', on pin 2, that sends MIDI messages with note 'C4' (60) on channel 1, with velocity 127
    Digital button(2, C4, 1, velocity);
    void setup() {}
      // Refresh the button (check whether the button's state has changed since last time, if so, send it over MIDI)
    Jan 2017
    Maastricht
    169
    The midi controller library is hardly used by anyone here and it's use is not actually recommended. See the Using USB MIDI page for info on how to connect many pots & buttons. Also have a look at the "Many_Knobs_Buttons" example provided with the Teensyduino installation (Menu: File > Examples > Teensy > USB_MIDI).
    Feb 2018
    154
    Why is it not recommended? I tried the"Many_Knobs_Buttons" sketch, I couldn't get it to work. The pots just flicker and it doesn't say what value the pull down resistors should be for the digital pins. The 2 examples above work, I'm hoping someone can show me how adjust the codes for more buttons and pots.
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,164
    Quote Originally Posted by edrummer View Post
    Why is it not recommended? ...
    Author supports the product on GitHub. I wouldn't say it's not recommended but I'm not sure what it brings you can't do without it just as easily.
    https://github.com/tttapa/MIDI_controller/issues/87
    Note here he cites 'help from the forum' which was me guessing what was wrong with his code and how to fix it.
    ...I tried the"Many_Knobs_Buttons" sketch, I couldn't get it to work....
    You could have asked for help.
    ... The pots just flicker ...
    Usually you have a pin configured but not tied to a stable voltage (ground, hot or anywhere in between but it cannot be 'floating').
    If you mean you flicker between adjacent values then you can change the sensitivity to eliminate this. [Edit - forgot this is ResponsiveAnalogRead and I've not built the sensativitiy in yet but it's very rare to have pots so noisy that the three-bit reduction and ResponsiveAnalogRead with default settings won't sort it out.]
    A decent MIDI monitor's output could tell me what your problem is, if you want to try. But it's almost always a bad connection to a pin or the maker not being aware that all analog pins configured must be connected to a stable voltage.
    Feb 2018
    154
    Ah, there you are! The drum pad works great! I mean when I use the many buttons and knobs sketch with Ableton and map the pot to one of the parameters like volume, it just goes crazy flickering sporadically and the digital switches do nothing. I may be doing something wrong but the 2 examples in#1 work
    Feb 2018
    154
    Again, the 2 examples in post #1 work fine without any extra components except that the pots don't max out soon enough, like there's an extra 10% left to turn but I think that can be adjusted.
    1,155
    That's because it configures each digital pin with an internal pullup resistor:
        pinMode(DIGITAL_PINS[i], INPUT_PULLUP);
    which means you don't need to add external resistors.
    Which Teensy are you using to handle the 24 pots and 24 buttons?
    Pete
    Feb 2018
    154
    3.6, the many knobs / buttons still does not work with Ableton
    Feb 2018
    154
    So with the many buttons and knobs sketch there are 6 analog and 3 digital pins that are hot, the rest are grayed out. Just to test, I connected 3 pots to A0,A1,A2 and put 10k resistors to gnd. on the other 3. I have 2 buttons connected to digital pins 0 and 1. still flickering sporadically.
    i
    1,155
    Have you modified the Many_Buttons_Knobs code to use your specific analog and digital pins. If so, which ones are you using? Post the code.
    Pete
    Feb 2018
    154
    I have not touched the code, please don't stray from the original post. I've tried the Many_Buttons_Knobs sketch every way I can, It doesn't work, the two in the first post do. I just need to know how to adjust the codes to use multiple pins.
    Feb 2013
    1,164
    Go ask on GitHub?
    He does reply but not right away.
    1,155
    I haven't a clue what you have tried with that sketch but obviously everything you've done is wrong.
    Post a version of the sketch, explain what it is doing wrong and perhaps we can figure it out so that you can have multiple buttons and pots.
    Pete
    Feb 2018
    154
    which sketch? I haven't touched the many buttons one and the others are posted in#1[CODE][/* Use arrays to manage lists of knobs/pots and pushbuttons.
    By Leif Oddson
    https://forum.pjrc.com/threads/45376
    This more complex example demonstrates how to use arrays to
    manage a larger number of inputs, without duplicating your
    code for every signal.
    You must select MIDI from the "Tools > USB Type" menu
    //************LIBRARIES USED**************
    // include the ResponsiveAnalogRead library for analog smoothing
    // include the Bounce library for 'de-bouncing' switches -- removing electrical chatter as contacts settle
    #include <Bounce.h>
    //usbMIDI.h library is added automatically when code is compiled as a MIDI device
    // ******CONSTANT VALUES********
    // customize code behaviour here!
    const int channel = 1; // MIDI channel
    const int A_PINS = 6; // number of Analog PINS
    const int D_PINS = 3; // number of Digital PINS
    const int ON_VELOCITY = 99; // note-one velocity sent from buttons (should be 65 to 127)
    // define the pins you want to use and the CC ID numbers on which to send them..
    const int ANALOG_PINS[A_PINS] = {A0,A1,A2,A3,A4,A5};
    const int CCID[A_PINS] = {21,22,23,24,25,26};
    // define the pins and notes for digital events
    const int DIGITAL_PINS[D_PINS] = {0,1,2};
    const int note[D_PINS] = {60,61,62};
    const int BOUNCE_TIME = 7; // 5 ms is usually sufficient
    const boolean toggled = true;
    //******VARIABLES***********
    // a data array and a lagged copy to tell when MIDI changes are required
    byte data[A_PINS];
    byte dataLag[A_PINS]; // when lag and new are not the same then update MIDI CC value
    // not sure if there is a better way... some way run a setup loop on global array??
    // use comment tags to comment out unused portions of array definitions
    // initialize the ReponsiveAnalogRead objects
    ResponsiveAnalogRead analog[]{
    {ANALOG_PINS[0],true},
    {ANALOG_PINS[1],true},
    {ANALOG_PINS[2],true},
    {ANALOG_PINS[3],true},
    {ANALOG_PINS[4],true},
    {ANALOG_PINS[5],true}/*,
    {ANALOG_PINS[6],true},
    {ANALOG_PINS[7],true},*/
    // initialize the bounce objects
    Bounce digital[] = {
    Bounce(DIGITAL_PINS[0],BOUNCE_TIME),
    Bounce(DIGITAL_PINS[1], BOUNCE_TIME),
    Bounce(DIGITAL_PINS[2], BOUNCE_TIME)/*,
    Bounce(DIGITAL_PINS[3], BOUNCE_TIME),
    Bounce(DIGITAL_PINS[4], BOUNCE_TIME),
    Bounce(DIGITAL_PINS[5], BOUNCE_TIME),
    Bounce(DIGITAL_PINS[6], BOUNCE_TIME),
    Bounce(DIGITAL_PINS[7], BOUNCE_TIME),*/
    // loop to configure input pins and internal pullup resisters for digital section
    for (int i=0;i<D_PINS;i++){
    getAnalogData();
    getDigitalData();
    while (usbMIDI.read()) {
    // controllers must call .read() to keep the queue clear even if they are not responding to MIDI
    //************ANALOG SECTION**************
    void getAnalogData(){
    for (int i=0;i<A_PINS;i++){
    // update the ResponsiveAnalogRead object every loop
    analog[i].update();
    // if the repsonsive value has change, print out 'changed'
    if(analog[i].hasChanged()) {
    data[i] = analog[i].getValue()>>3;
    if (data[i] != dataLag[i]){
    dataLag[i] = data[i];
    usbMIDI.sendControlChange(CCID[i], data[i], channel);
    void getDigitalData(){
    digital[i].update();
    if (digital[i].fallingEdge()) {
    usbMIDI.sendNoteOn(note[i], ON_VELOCITY, channel);
    // Note Off messages when each button is released
    if (digital[i].risingEdge()) {
    usbMIDI.sendNoteOff(note[i], 0, channel);
    }/CODE]
    Feb 2018
    154
    Sorry if I got a little impatient, I changed boards a new 3.6 and re booted everything. I was able to get 3 pots to work with the Many_Buttons_Knobs sketch but not the buttons. There's hope I'm still trying
    Feb 2018
    154
    I don't know if this is what you mean, if not please post a version of the complete code that I can copy.
       By Leif Oddson
    #include <Bounce.h>
    //const int ANALOG_PINS[A_PINS] = {A0,A1,A2,A3,A4,A5};
    //const int CCID[A_PINS] = {21,22,23,24,25,26};
    byte data[A_PINS];
    //ResponsiveAnalogRead analog[]{
      //{ANALOG_PINS[0],true},
      //{ANALOG_PINS[1],true},
      //{ANALOG_PINS[2],true},
      //{ANALOG_PINS[3],true},
      //{ANALOG_PINS[4],true},
      //{ANALOG_PINS[5],true}/*,
      //{ANALOG_PINS[6],true},
      //{ANALOG_PINS[7],true},*/
      getAnalogData();
      getDigitalData();
        analog[i].update();
    Feb 2018
    154
    OK without changing the code the buttons turn the parameter off but not on, for example when I map a button to the record function it will turn it off but I have to turn it on with the mouse. Also there is some chatter with the buttons some other functions are flickering
    1,155
    Let's get the digital pins working first. Modify the code in the loop function and just comment out the analog part:
    //  getAnalogData();
    That will stop it flooding the receiving end with messages about the pots changing value.
    Now run the code (compile it with USB type "Midi" or "Serial + MIDI") and then touch a wire from pin zero to ground. When I do that, Midi-OX on Windows sees a note on event and a note off event when I remove the wire. It is sending note 60 as defined in the code. Pins 1 and 2 also send their specified note event.
    Pete
    1,155
    No. All you do is comment the one statement in the loop statement that I showed.
    //  getAnalogData();
    Here's the whole thing:
    By Leif Oddson
    #include <Bounce.h>
    byte data[A_PINS];
    ResponsiveAnalogRead analog[] {
      while(!Serial);
      Serial.println("Start");
      for (int i=0; i<D_PINS; i++) {
    //  getAnalogData();
      getDigitalData();
      for (int i=0; i<A_PINS; i++) {
        analog[i].update();
          if (data[i] != dataLag[i]) {
    Pete
    Feb 2018
    154
    Ok I copied and pasted the code, now nothing, when I press the buttons.
    Feb 2018
    154
    Anybody know of a sketch where more than 1 buttons work?
    Feb 2018
    154
    I went back to the buttons sketch, I have 2 buttons connected to pins 0 and 1, only the one button works. I tested the buttons there fine any suggestions? Also this code can 't compile for teensy 3.6
      This is the code I used for my specific MIDI controller.
      I used an Arduino Leonardo with 4 faders on A0-A3, 8 potentiometers on A4-A11, a rotary encoder on pin 0&1, 4 toggle switches on pins 2, 3, 5 and 7, a toggle switch (for bank select) on pin 11, and an LED on pin 13.
      When bank select is 0, faders 1-4 are channel volumes 1-4, potSide 1-4 are pan/balance of channel 1-4, switches 1-4 are mute channel 5-8.
      When bank select is 1, faders 1-4 are channel volumes 5-8, potSide 1-4 are pan/balance of channel 5-8, switches 1-4 are mute channel 1-4.
      PotTop 1-4 are not in the bank, because I use them as effect or EQ parameters, and they are channel independent.
      Enc1 is used for scrolling.
      Note that I used a custom control mapping in my DAW.
      If you are using a Teensy, make sure you have the USB type set to MIDI.
      If you are using an Arduino Uno or Mega, use the HIDUINO firmware for the ATmega16U2.
      Written by tttapa, 07-09-2017
    #define USE_ROTARY_ENCODER
    const uint8_t velocity = 0b01111111; // The velocity of the buttons (0b01111111 = 127 = 100%)
    const unsigned int latchTime = 100;  // How long a note will be held on, in DigitalLatch mode (in milliseconds).
    const int speedMultiply = 1; // If the jog wheels or other encoders are too slow in your software, increase this value
                                 // (it will be multiplied with the actual speed of the encoder, as the name implies.) Default is 1.
    //_____________________________________________________________________________________________________________________________________________________________________________________________
    Analog faders[] = {
        {A0, MIDI_CC::Channel_Volume, 1}, // Create a new instance of class 'Analog' on pin A0, controller number 0x07 (channel volume), on MIDI channel 1.
        {A1, MIDI_CC::Channel_Volume, 2},
        {A2, MIDI_CC::Channel_Volume, 3},
        {A3, MIDI_CC::Channel_Volume, 4},
    Analog knobsTop[] = {
        {A4, 0x10, 1}, // Create a new instance of class 'Analog' on pin A4, controller number 0x10 (General Purpose Controller 1), on MIDI channel 1.
        {A5, 0x11, 1},
        {A6, 0x12, 1},
        {A7, 0x13, 1},
    Analog knobsSide[] = {
        {A8,  MIDI_CC::Pan, 1}, // Create a new instance of class 'Analog' called 'potSide1', on pin A8, controller number 0x0A (pan), on MIDI channel 1.
        {A9,  MIDI_CC::Pan, 2},
        {A10, MIDI_CC::Pan, 3},
        {A11, MIDI_CC::Pan, 4},
    DigitalLatch switches[] = {
        {2, 0x10, 1, velocity, latchTime}, // Create a new instance of class 'DigitalLatch' on pin 0, note number 16 (mute) on MIDI channel 1, with a predefined latch time
        {3, 0x11, 1, velocity, latchTime},
        {5, 0x12, 1, velocity, latchTime},
        {7, 0x13, 1, velocity, latchTime},
    RotaryEncoder enc = {1, 0, 0x2F, 1, speedMultiply, NORMAL_ENCODER, TWOS_COMPLEMENT}; // Create a new instance of class 'RotaryEncoder' called enc, on pins 1 and 0, controller number 0x2F, on MIDI channel 1, at normal speed, using a normal encoder (4 pulses per click/step), using the TWOS_COMPLEMENT sign option
    Bank bank(4); // A bank with four channels
    BankSelector bankselector(bank, 11, LED_BUILTIN, BankSelector::TOGGLE); // A bank selector with a single toggle switch on pin 11 and an LED for feedback on pin 13
        bank.add(faders, Bank::CHANGE_CHANNEL); // Add the control elements to the bank
        bank.add(knobsSide, Bank::CHANGE_CHANNEL);
        bank.add(switches, Bank::CHANGE_ADDRESS);
    void loop() // Refresh all inputs
    1,155
    Yes, the one I posted in #19. It uses pins 0, 1 and 2 and each one causes a MIDI note to be sent.
    Pete
  24. #24
    Feb 2018
    154
    I found it! changed the button from pin 1 to pin 2 and both worked. pin#1 isn't working
  25. #25
    Feb 2013
    1,164
    I finally get what the chain selector is after a quick search.
    What you need is another array that holds what value is sent with the CC message instead of just off and on.
    Then you can configure buttons on the same CC number but different values.
    I'll need some time at a compiler and I'm not near one currently.
    The other remaining issue is whether they latch or just fire the CC message when pressed and there is no OFF value sent and whether this is the same for all buttons or the behaviour of some buttons is still on-when-pressed or latching.
