Results 1 to 2 of 2
Thread: Serial1.write9bit(word) usage question
    Jul 2019
    1
    Anyone have an example or explanation on how to use Serial1.write9bit(word) for Teensy 3.2 to set or cleared the 9th bit? I am new to Teensy. I was able to modify the HardwareSerial.h with SERIAL_9BIT_SUPPORT. I am able to compiled with HWSERIAL.begin(115200, SERIAL_9N1);
    I am confused on how to set or cleared the 9th bit. Could anyone provide me an example?
    For instance, I am trying to send a byte 0x32 with 9th bit set. Do I use: Serial1.write9bit(0x328) ? Since 0x8 is 1000 (bits)
    and if my byte is 0x01 with 9th bit cleared: do I use Serial1.write9bit(0x010) ?
    Thank you
    20,323
    Quote Originally Posted by sheng View Post
    Try Serial1.write9bit(0x132)
