Page 11 of 11 FirstFirst ... 9 10 11
Results 251 to 266 of 266
Thread: ST7789_t3 (part of ST7735 library) support for displays without CS pin
  1. #251
    4,213
    @KurtE
    Just did the merge and it now works like a charm with and without frame buffer.
  2. #252
    Hello, I tried using the latest update from github (the t4 rewrite branch). I currently have a Teensy 4 and a ST7789 screen wired up. I have tried both the CS and no CS configs, with the only other change being switching pin SCK to 14 instead of 13. So far I get no picture with the uncanny eye example (I get the backlight though). Can I confirm that SDA is MOSI according to this pinout? https://facelesstech.files.wordpress.../13_pinout.jpg
    Maybe I'm missing something else, but I'm pretty excited to get this running!
  3. #253
    4,213
    Yes SDA goes to MOSI.
    You will need to do some reconfiguration for your display though. The 7789 example is set up to use SPI and SPI1 as well as a 240x240 displat. If you are using only SPI with CS pins specified you will make sure you comment out:
    #define ST77XX_ON_SPI_SPI1
    and then in the config file adjust these lines for your display:
    #else
      //CS  DC MOSI SCK RST WINK ROT INIT
       {0,  2,  26, 27,  3, -1,  0, INITR_144GREENTAB }, // RIGHT EYE display-select and wink pins, no rotation
       {10, 9,  11, 13,  8, -1,  0, INITR_144GREENTAB }, // LEFT EYE display-select and wink pins, no rotation
    Think you get the idea - let us know if you run into problems
  4. #254
    Thanks for the reply! I commented out the #define ST77XX_ON_SPI_SPI1 in the main sketch, and updated both pin 13s on the config to be pin 14. I'm still not getting any picture on the screen, although this is the first sketch I'm running since I got my Teensy 4. I have no light on the Teensy when initially plugged in, but when programming, I press the button on the Teensy and get a dim red light. From what I can tell, it appears to be uploading the code right. Also if it's important, I got all the ground and LED Cathode connected together for ground. I also have the power and LED anode paired together in the 3v pin.
  5. #255
    4,213
    Can you post a link to the exact display you are using and maybe a schematic/photo of your wiring to the T4. Have to remember that the T4 is not 5v tolerant. The adafruit display I have uses 3.3v and does not have a LED pin
    Also I would try running the graphictest.ino sketch first before trying it with uncanny eyes.
  6. #256
    I've been using these:https://www.aliexpress.com/item/3295...chweb201603_52
    I've gotten them to work with a raspberry pi before, although this is my first time trying them on other hardware. I don't have anything wired to 5v, except the USB cable powering the teensy. I'll see if I can get a good picture of my wiring shortly.
    Edit:
    For clarity's sake, wiring is, pins:
    1,2,5,6,12 - Ground - Black
    3,4 - 3.3v - Red
    7 - D/C - White
    8 - CS - Blue
    9 - SCL - Green
    10 - SDA - Yellow
    11 - Reset - Orange
  7. #257
    4,213
    Quote Originally Posted by FroggestSpirit View Post
    Ok - never seen any display like that before - where did you find the specs for the pinouts etc?
  8. #258
    I believe they're the same as the adafruit ones, just without the board they connect to. This site seems to have a bit more on the wiring, but I usually just google ST7789 pinout to reference. https://facelesstech.wordpress.com/2...-raspberry-pi/
    I've updated my last post with pictures and wiring.
    (On a side note, is there a way to handle the pictures better? spoiler tags didn't seem to work and the code tag made the section very thin)
  9. #259
    4,213
    Ok - lets start with your wiring:
    Display - Pin Desc  - T4 (what you have)  - T4 what should be
    1,2,5,6,12    - Ground    - Black    -  no problem
    3,4               - 3.3v        - Red       - no problem
    7                   - D/C       - White     - Pin 9       ---  ok this can be any digital pin
    8                   - CS         - Blue       - Pin 10    ----  ok this is typical for CS pin
    9                   - SCL       - Green     - Pin 14    ---- SPI CLOCK IS ON PIN 13 not pin 14
    10                  - SDA       - Yellow   - Pin 11   -  Pin 11 so this is ok.
    11                  - Reset     - Orange  - Pin 8     -  Pin 8 typical and what I am using
    Also use a volt meter just to check your wiring to make sure you don't have any shorts.
    So would say at a minimum you need to fix your clock wire. But I am a little concerned that the red light is on dim when you load the sketch. Just as check load the blink sketch and make sure the T4 blinks after rewiring and checking connections especially gnds and 3.3v lines.
    Next I would run the graphicstest sketch to make sure wiring is correct.
    Hope this helps
  10. #260
    Dec 2018
    4
    Are you sure you have enough power on the 3.3 volt line? That display may require more power than the Teensy can provide. You may need an external power supply.
  11. #261
    I switched the SCLK pin to 13, the UncannyEyes example still did not work (after correcting config to use pin 13 again). However, I ran the scrolltest, and got garbled pixels (every pixel was a random color) This was not animated. The only change I made to the sketch was to switch the screen size to 240x240 (I think it uses ST7789 by default too). I'm sure the screen has enough power, it's a pretty low powered screen, though I tried powering the teensy with a wall port and got the same results. After a few power cycles, the "random" pixels appear to be consistant with what colors are where, giving me the same image each time.
    Edit: also forgot to add, I tested for continuity from the ribon cable on the screen to the ports on the teensy, everything seems to be wired good without data pins shorting.
    Edit2: got it to work! didn't realize the serial window needed to be up. (commented the while(!Serial) out to bypass this). Thanks for your help!
  12. #262
    4,213
    Scrolltest has issues with the ST7789 probably should delete that function but hoping to figure out how to readpixels from the display. Please try and run the graphicstest.ino sketch.
    EDIT: did you check that you don't have any solder bridges - in the photo it looked like maybe you did?
  13. #263
    the only bridges i have were for connecting the multiple grounds and the led to the 3v input. is there a separate folder for the graphics test? the only one i seen was for the ILI screen, not the ST ones. though the scroll test did seem to work flawlessly from what i could tell
  14. #264
    4,213
    Sorry - when I posted my question there were no edits in you post #261.
    So - glad you got it working
  15. #265
    3,320
    I was doing some runs of uncanny eyes this morning on a Teensy 4.0 using the 240x240 Adafruit displays, one on SPI0 using the default 10 CS pin, and the second display on SPI1 using the default 0 pin for CS1. I'll post numbers later, once I've done tests of the various configurations I've run (Teensy 3.2 on 128x128 TFT displays, Teensy 3.5 on 128x128 OLED displays, Teensy 4.0 on 240x240 TFT IPS displays, Adafruit Hallowing M0 on a single 128x128 display, Adafruit Hallowing M4 on a single 240x240 display, Adafruit Monster M4SK on a pair of 240x240 displays).
    I was thinking about adding the audio shield to get the SD drive (which also uses pin 10). So I moved the CS pin from pin 10 to pin 22 to see what the degradation would be, and I was surprised that there was no degradation in using something other than pin 10. I had async updates on and I was using the ST7735_t3 library from the 1.48 release. Does that mean with the T4, that unlike the T3 series, we don't need to pick CS and D/C from favored pins?
    Has anybody actually run another SPI device along with the monitor? Do you need to insert the appropriate beginTransaction endTransaction calls in key places in the monitor code? Or do I have to turn off the async support? Obviously if you are sharing the SPI bus, you need good pull-up resistors on the CS/DC pins. Also obviously, you can't use the no-CS pin cheapo displays on a shared SPI bus.
  16. #266
    3,320
    Cool Timings for different uncanny eyes
    This morning I decided to do timing runs for all of the uncanny eye variants I have setup. Note, these don't necessarily have the same options compiled it, and they are using somewhat different base sources. The only weird thing is the Teensy 4.0 with 1 eye is reporting 15-16fps, while 2 eyes tends to be 30-32 fps.
    The T3.2 and T3.5 use the traditional approach of 1 SPI bus with 2 displays on it. I haven't tried using the second SPI bus on the 3.5.
    I found I could not use the T3.2 with the original sources and have the display show up, but I used my hacked up sources setting the SPI bus to 24Mhz.
    For the Teensy 4.0, I did define USE_ASYNC_UPDATES, and I see from the serial monitor that is using the frame buffer for both displays. I am using the ST7735_t3 from the Teensydunio 1.48 release. I am using 2 separate SPI buses.
    Teensy 3.2,   MK20DX256VLH7, M4, cpu  96Mhz, spi 24Mhz, TFT,  128x128, ST7735,  2 eyes: 85fps
    Teensy 3.2,   MK20DX256VLH7, M4, cpu  96Mhz, spi 24Mhz, TFT,  128x128, ST7735,  1 eye:  85fps
    Teensy 3.5,   MK64FX512,     M4, cpu 120Mhz, spi 18Mhz, OLED, 128x128, SSD1351, 2 eyes: 56fps
    Teensy 3.5,   MK64FX512,     M4, cpu 120Mhz, spi 18Mhz, OLED, 128x128, SSD1351, 1 eye:  56fps
    Teensy 4.0,   i.MX RT 1062,  M7, cpu 600Mhz, spi 48Mhz, TFT,  240x240, ST7789,  2 eyes: 30-32fps
    Teensy 4.0,   i.MX RT 1062,  M7, cpu 600Mhz, spi 48Mhz, TFT,  240x240, ST7789,  1 eye:  15-16fps
    Hallowing M0, ATSAMD21G18,   M0, cpu  48Mhz, spi 12Mhz, TFT,  128x128, ST7735,  1 eye:  22fps
    Hallowing M4, ATSAMD51G18,   M4, cpu 120Mhz, spi 50Mhz, TFT,  240x240, ST7789,  1 eye:  27-31fps
    Monster M4SK, ATSAMD51G19,   M4, cpu 120Mhz, spi 50Mhz, TFT,  240x240, ST7789,  2 eyes: 20-29fps
