Results 1 to 5 of 5
Thread: Controlling the line-out volume
    Junior Member Frederc Segard's Avatar
    Jul 2019
    Montreal, QC, Canada
    1
    Is there any way to control the line-out volume on the Teensy Audio Board? When I do the following code, it works with the headphone output, but not the line-out.
    float vol = analogRead(15);
    AudioControl.volume(vol);
    Thanks in advance,
    Fred
    Use the "amp" component, it's next to the mixer in the GUI. Scale your ADC reading to the range of 0~1.0, and then call amp1.gain(vol).
    May 2016
    220
    ... and donj't forget you can set the line-in and line_out gains by setting the voltage range on the SGTL5000 in 1.5 dB steps for example:
      codec.lineInLevel(15);             // Set codec input voltage level to most sensitive
      codec.lineOutLevel(13);            // Set codec output voltage level to most sensitive
    1,170
    You also need to unmute the lineout first.
      sgtl5000_1.unmuteLineout();
      // According to info in libraries\Audio\control_sgtl5000.cpp
      // 31 is LOWEST output of 1.16V and 13 is HIGHEST output of 3.16V
      sgtl5000_1.lineOutLevel(15);
    Pete
    May 2016
    220
    I've never done that on any of my projects. For example in my SDR project, here is the SGTL5000 initialization code
      AudioNoInterrupts();
      codec.inputSelect(AUDIO_INPUT_LINEIN);
      codec.volume(0.7);
      codec.enable();
      AudioInterrupts();
    and then I use lineInLevel directly integrated into my RF gain scheduler without problem.
