Results 1 to 8 of 8
Thread: I can't play Wav files
    Jul 2019
    7
    I'm trying to play SDfiles with a TDA1543 (similar to PT8211), but nothing happen.
    I successfully tried the ListFiles Sketch, so I know that Teensy 3.5 can access the SDcard and sees the 4 files as per the following serial monitore message :
    Initializing SD card...initialization done.
    SYSTEM~1/
    INDEXE~1 76
    SDTEST1.WAV 16787550
    SDTEST4.WAV 17173152
    SDTEST3.WAV 13617358
    SDTEST2.WAV 16425698
    done!
    However, when I try to play those Files, nothing work.
    Here is what I have as a programm
    The serial monitor never write anything and I get no sound from the DAC
    // Simple WAV file player example
    File root;
    AudioPlaySdWav           playWav1;
    AudioOutputPT8211        pt8211_1;
    AudioConnection          patchCord1(playWav1, 0, pt8211_1, 0);
    AudioConnection          patchCord2(playWav1, 1, pt8211_1, 1);
    const int chipSelect = BUILTIN_SDCARD;
      AudioMemory(8);
      Serial.print("Initializing SD card...");
      if (!SD.begin(chipSelect)) {
        Serial.println("initialization failed!");
        return;
      Serial.println("initialization done.");
      root = SD.open("/");
      Serial.print("Playing file: ");
      Serial.println(filename);
      // Start playing the file.  This sketch continues to
      // run while the file plays.
      playWav1.play(filename);
      // A brief delay for the library read WAV info
      delay(5);
      // Simply wait for the file to finish playing.
      while (playWav1.isPlaying()) {}
      playFile("SDTEST1.WAV");  // filenames are always uppercase 8.3 format
      playFile("SDTEST2.WAV");
      playFile("SDTEST3.WAV");
      playFile("SDTEST4.WAV");
      delay(1500);
    Do you have any idea of what's missing ?
    Thank you all
    Jean
    20,459
    Try adding "while (!Serial) ;" at the beginning of loop, so Teensy waits for the serial monitor open.
    Focus on the easy problem first, just getting printing to work to the serial monitor.
    2,135
    There's a known problem with WavFilePlayer (AudioPlaySdWav) and BUILTIN_SDCARD since Teensyduino 1.46, see
    https://forum.pjrc.com/threads/56355...ignment-issues
    Jul 2019
    7
    Thank you Paul for taking care.
    I can print the SD card file content, no problem.
    I have added a few print status to the file, it prints the status, but I get no sound.
    I checked my DAC on a Raspberry Pi => Music
    I connected the DAC PSU to the Teensy while playing (with Teensy and Pi GND tied) => Music
    I tried a Simpler sketch (PT8211Sine)
    AudioSynthWaveform       waveform1;      //xy=110,75
    AudioOutputPT8211        pt8211_1;          //xy=303,78
    AudioConnection          patchCord1(waveform1, 0, pt8211_1, 0);
    AudioConnection          patchCord2(waveform1, 0, pt8211_1, 1);
      AudioMemory(15);
      waveform1.frequency(440);
      waveform1.amplitude(0.99);
    No SOUND
    My DAC is TDA1543A (Right Justified DAC like PT8211)
    Hardware connection is
    Hardware
    Pin Signal Direction
    9 BCK Output
    22 DIN Output
    23 FS Output
    VUSB PSU 5V Output
    GND GND Output
    Any idea of what is wrong ?
    Thank you
    Jean
    2,135
    Quote Originally Posted by bricolodu13 View Post
    Thank you
    Jean
    see post #3, though if your sine wave isn't making sound, then you have other problems ...
    Jul 2019
    7
    Hello all,
    I spent a little time today to try to play music.
    1/ Sine is working now, I swapped the TDA1543A that is supposed to be similar to PT8211 (Right Justified) to a TDA1543 (I2S) and mod the code from pt8211 to i2s : OK
    2/ I tried again playing sd file and add some debugging print when I understood that the problem was the function AudioPlaySdWav that was the problem and understood what you wrote Manitou !
    However, I have absolutely no clue on how to solve that issue!
    I looked for AudioPlaySdWav:lay() but couldn't find it
    Sorry !
    2,135
    You need to find the teensy audio lib that was installed on your system as part of Teensyduino (hardware/teensy/avr/libraries/Audio/), and edit
    play_sd_wav.h and change buffer to uint8_t buffer[512] __attribute__ ((aligned (4))); // buffer one block of data
    in play_sd_wav.cpp comment out __disable_irq() before the wavfile = SD.open(filename)
    https://forum.pjrc.com/threads/54711...l=1#post207700
    EDIT: Paul's FIX 8/11/19 get latest from https://github.com/PaulStoffregen/SD
    Jul 2019
    7
    Hello Manitou, Now it is playing music thank you
