Results 1 to 11 of 11
Thread: IRremote problems with audio sketches.
    I recently had a problem where I couldn't get the serial monitor to connect. As I hadn't updated for a long time I thought it could be this. I did a complete reinstall of Arduino and Teensyduino.
    All worked fine, I can now connect to serial monitor but all my audio sketches with IRremote.h in them no longer compile. If I remove all the IR code, no probs. If I make a sketch with just the IR code on its own, no probs.
    The following is the complete code that used to compile and is actually running on a teensy now but will no longer compile since I updated.
    #include <IRremote.h>
    #include <Encoder.h>
    #include <Bounce.h>
    #include <EEPROM.h>
    AudioInputI2SQuad        i2s_quad1;      //xy=62,121
    AudioPlaySdWav           playSdWav2;     //xy=71,305
    AudioPlaySdWav           playSdWav1;     //xy=73,236
    AudioMixer4              mixer2;         //xy=218,249
    AudioMixer4              mixer1;         //xy=219,85
    AudioMixer4              mixer3;         //xy=219,317
    AudioMixer4              mixer4;         //xy=224,165
    AudioMixer4              mixer5;         //xy=348,122
    AudioMixer4              mixer6;         //xy=373,255
    AudioMixer4              mixer7;         //xy=490,181
    AudioFilterStateVariable filter1;        //xy=594,38
    AudioFilterStateVariable filter3;        //xy=609,113
    AudioFilterStateVariable filter5;        //xy=611,226
    AudioFilterStateVariable filter2;        //xy=722,35
    AudioFilterStateVariable filter4;        //xy=732,114
    AudioFilterStateVariable filter6;        //xy=738,223
    AudioMixer4              mixer8;         //xy=841,43
    AudioMixer4              mixer9;         //xy=861,131
    AudioMixer4              mixer10;        //xy=865,220
    AudioOutputI2SQuad       i2s_quad2;      //xy=1004,52
    AudioConnection          patchCord1(i2s_quad1, 0, mixer4, 0);
    AudioConnection          patchCord2(i2s_quad1, 1, mixer1, 0);
    AudioConnection          patchCord3(i2s_quad1, 2, mixer1, 1);
    AudioConnection          patchCord4(playSdWav2, 0, mixer3, 0);
    AudioConnection          patchCord5(playSdWav2, 1, mixer3, 1);
    AudioConnection          patchCord6(playSdWav1, 0, mixer2, 0);
    AudioConnection          patchCord7(playSdWav1, 1, mixer2, 1);
    AudioConnection          patchCord8(mixer2, 0, mixer4, 1);
    AudioConnection          patchCord9(mixer1, 0, mixer5, 0);
    AudioConnection          patchCord10(mixer3, 0, mixer6, 1);
    AudioConnection          patchCord11(mixer4, 0, mixer5, 1);
    AudioConnection          patchCord12(mixer5, 0, mixer6, 0);
    AudioConnection          patchCord13(mixer6, 0, mixer7, 0);
    AudioConnection          patchCord14(mixer7, 0, filter1, 0);
    AudioConnection          patchCord15(mixer7, 0, filter3, 0);
    AudioConnection          patchCord16(mixer7, 0, filter5, 0);
    AudioConnection          patchCord17(filter1, 0, filter2, 0);
    AudioConnection          patchCord18(filter3, 0, filter4, 0);
    AudioConnection          patchCord19(filter5, 0, filter6, 0);
    AudioConnection          patchCord20(filter2, 2, mixer8, 0);
    AudioConnection          patchCord21(filter4, 2, mixer9, 0);
    AudioConnection          patchCord22(filter6, 2, mixer10, 0);
    AudioConnection          patchCord23(mixer8, 0, i2s_quad2, 1);
    AudioConnection          patchCord24(mixer9, 0, i2s_quad2, 0);
    AudioConnection          patchCord25(mixer10, 0, i2s_quad2, 3);
    AudioControlSGTL5000     sgtl5000_1;     //xy=67,20
    AudioControlSGTL5000     sgtl5000_2;     //xy=195,20
    #define SDCARD_CS_PIN    10
    #define SDCARD_MOSI_PIN  7
    #define SDCARD_SCK_PIN   14
    const int ledPin1 =  3;
    const int ledPin2 =  4;
    const int ledPin3 =  5;
    #define RECV_PIN      2
    uint16_t lastCode = 0;
    const uint16_t BUTTON_volup = 0xFFA857; //ir remote codes
    const uint16_t BUTTON_voldown = 0xFFE01F;
    const uint16_t BUTTON_back = 0xFF22DD;
    const uint16_t BUTTON_stop = 0xFFC23D;
    const uint16_t BUTTON_fwd = 0xFF02FD;
    const uint16_t BUTTON_1 = 0xFF30CF;
    const uint16_t BUTTON_2 = 0xFF18E7;
    IRrecv irrecv(RECV_PIN);
    decode_results results;
    int volstore ;
    float vol =  0.0  ;
    Bounce button1 = Bounce(8, 15);  // 15 = 15 ms debounce time
    Encoder myEnc(1, 0);
    float oldPosition1  = 0.0;
     irrecv.enableIRIn();
     pinMode (RECV_PIN, INPUT);
      AudioMemory(60);
     pinMode(ledPin1, OUTPUT);
     pinMode(ledPin2, OUTPUT);
     pinMode(ledPin3, OUTPUT);
     pinMode(8, INPUT_PULLUP);
      SPI.setMOSI(SDCARD_MOSI_PIN);
      SPI.setSCK(SDCARD_SCK_PIN);
        while (1) {
      sgtl5000_1.setAddress(LOW);
      sgtl5000_1.enable();
      sgtl5000_1.lineOutLevel(13);
      sgtl5000_1.lineInLevel(0);
      sgtl5000_1.muteHeadphone();
      sgtl5000_2.setAddress(HIGH);
      sgtl5000_2.enable();
      sgtl5000_2.lineOutLevel(13);
      sgtl5000_2.lineInLevel(0);
      sgtl5000_2.muteHeadphone();
    // bass filter set
      filter1.frequency(200);
      filter2.frequency(40);
    // mid filter set
      filter3.frequency(8000);
      filter4.frequency(200);
    // high filter set
      filter5.frequency(18000);
      filter6.frequency(8000);
    // SD1 to mono
       mixer2.gain(0, 0.5);
       mixer2.gain(1, 0.5);
    // SD2 to mono
       mixer3.gain(0, 0.5);
       mixer3.gain(1, 0.5);
    // set sd2 to 0
       mixer6.gain(0, 1.0 );
       mixer6.gain(1, 0.0 );
    // set main vol to 0
       mixer7.gain(0, 0.0);
         // set bass vol to 0
       mixer8.gain(0, 0.0);
       // set mid vol to 0
       mixer9.gain(0, 0.0);
       // set high vol to 0
       mixer10.gain(0, 0.0);
       EEPROM.get(20,volstore);
       delay(5);
       Serial.println(volstore);
     float vol = (float)volstore / 100;
        mixer7.gain(0, vol);
     Serial.println( vol);
     digitalWrite(ledPin3, HIGH);
      // saves current volume in eeprom  when pressed
      button1.update();
      if (button1.fallingEdge()) {
            EEPROM.update(20,volstore);
         delay (5);
         digitalWrite(ledPin3, LOW);
         digitalWrite(ledPin2, HIGH);
         digitalWrite(ledPin2, LOW);
        float newPosition = myEnc.read();
      if (newPosition != oldPosition1) {
       oldPosition1 = newPosition;
      // Serial.println(newPosition);
        vol = vol + (newPosition / 20);
        if (vol>3){
          vol = 3;}
          if (vol<0.00){
          vol = 0.00;}
           Serial.println("vol");
           Serial.println(vol);
          mixer7.gain(0,vol);
           volstore = vol * 100;
     //   EEPROM.put(10,volstore);
      //  delay (10);
     //    Serial.println(EEPROM.read(10));
      myEnc.write(0);
    // Pan between line1 and line2
      int line = analogRead(A6);
      float line1 = (float)line / 1023.0;
      float line2 = 1.0 - line1;
      mixer1.gain(0, line1 );
      mixer1.gain(1, line2 );
     // Serial.println("mic1");
     // Serial.println(line1);
    // Pan between bluetooth and sd1
      int mic = analogRead(A3);
      float mic1 = (float)mic / 1023.0;
      float mic2 = 1.0 - mic1;
      mixer4.gain(0, mic1 );
      mixer4.gain(1, mic2 );
    //  Serial.println("music1");
     // Serial.println(mic1);
    // Pan between mic and music mixes
      int mix = analogRead(A2);
      float mix1 = (float)mix / 1023.0;
      float mix2 = 1.0 - mic1;
      mixer5.gain(0, mix1 );
      mixer5.gain(1, mix2 );
    //   Serial.println("mix1");
    //  Serial.println(mix1);
    // Bass volume
      int knob = analogRead(A17);
      float bass = (float)knob / 1023.0;
      mixer8.gain(0,bass);
    // Mid volume
      int knob1 = analogRead(A16);
      float mid = (float)knob1 / 1023.0;
      mixer9.gain(0,mid);
    // High volume
      int knob2 = analogRead(A7);
      float high = (float)knob2 / 1023.0;
      mixer10.gain(0,high);
     //set level between sd1/line1/line2/blue and sd2 while sd2 is playing
     if (playSdWav2.isPlaying() == true) {
        mixer6.gain(0, 0.5 );
        mixer6.gain(1, 0.5 );
         else {
     // ir buttons and decoder
      if (irrecv.decode(&results)) {
        uint16_t resultCode = (results.value & 0xFFFF);
        if (resultCode == 0xFFFF)
          resultCode = lastCode;
          lastCode = resultCode;
        switch (resultCode)
          case BUTTON_volup:
          vol = vol + 0.1;
        if (vol>3){
          vol = 3;}
          if (vol<0){
          vol = 0;}
          mixer7.gain(0,vol);
        case BUTTON_voldown:
          vol = vol - 0.1;
        if (vol>3){
          vol = 3;}
          if (vol<0){
          vol = 0;}
          mixer7.gain(0,vol);
          case BUTTON_back:
         //  digitalWrite(backbutton, HIGH);
           delay(500 );
       //    digitalWrite(backbutton, LOW);
           //   Serial.println("back");
          case BUTTON_stop:
           playSdWav1.stop();
           playSdWav2.stop();
           case BUTTON_fwd:
         //  digitalWrite(fwdbutton, HIGH);
       //    digitalWrite(fwdbutton, LOW);
           //   Serial.println("forward");
          case BUTTON_1:
              playSdWav1.stop();
             Serial.println("wav1");
              playSdWav1.play("1.WAV");
              delay(10); // wait for library to parse WAV info
          case BUTTON_2:
              playSdWav1.stop();
             Serial.println("wav2");
              playSdWav1.play("2.WAV");
          default:
            Serial.print("Unrecognized code received: 0x");
            Serial.println(results.value, HEX);
        irrecv.resume();
    Any help greatly appreciated, lemme know if I need to give more info.
    1,148
    I don't know why this works, but move all of these #includes:
    #include <Bounce.h>
    #include <EEPROM.h>
    to just before this:
    Pete
    P.S. I'm using Arduino 1.8.9 and TD 1.47 beta 4 and compiled it for a T3.6
    Thank you, you lovely person! It works again, woot! woot!
    Not sure why either but I do remember having some issues with the order of the IR stuff before.
    1,148
    I played with the order of the includes. It appears to be an interaction between Audio.h and IRremote.h.
    This works:
    #include <Bounce.h>
    #include <EEPROM.h>
    but this fails:
    #include <Bounce.h>
    #include <EEPROM.h>
    I tried some other variations but as long as IRremote.h is included after Audio.h there is no problem.
    I may dig into this later in the afternoon.
    Pete
    1,148
    The problem is that both the IRremote library (in IRremoteInt.h) and the Audio library (in synth_wavetable.h) use the name STATE_IDLE. Either or both of them should use a more specific name, e.g. IR_STATE_IDLE and AUDIO_STATE_IDLE, or maybe there's a better way to fix them.
    Pete
    Nice work, thanks again for taking the time.
    1,148
    BTW. The compiler gives a warning for each of these:
    because they are 24 bits but being crammed into 16 bits. Shouldn't those be uint32_t ? If so, so should this:
    Pete
    20,459
    Thanks for digging into this issue. I've put it on my (low priority) list of bugs to fix.
    Pete
    Haha, you are highlighting my noobitude. Most of my sketches have come from examples and code shared online, cobbled together and I don't have a huge understanding of how it all works. Mostly I'm just persistent enough to shuffle it until it works.
    I tried using uint32_t instead as per your suggestion but it then spits out all codes as unrecognised and ignores the actions attached to them.
    It's working fine as before though
    1,148
        switch (resultCode)
          case BUTTON_volup:
    The problem is that the result value from IRremote is declared to be a long integer. But you truncate that to 16 bits and store it in a 16-bit integer (resultCode) and then use that as the value for the switch statement. That then clashes with BUTTON_volup etc. being defined to be uint32_t.
    For now, I'd suggest you try using these two lines in place of the first two above:
        uint32_t resultCode = (results.value & 0xFFFFFF);
        if (resultCode == 0xFFFFFF)
    This will detect a REPEAT code but you should be aware that REPEAT is actually defined to be 0xFFFFFFFF.
    Pete
