Results 1 to 10 of 10
Thread: [teensy 3.6] using string.erase or string.insert generate basic_string error
    hi,
    using this code below i have errors compilation
    #include <string>
    void CHTTP::SetProtocolVersion(CSockProtocol protocol)
      switch (protocol)
        case HTTP10:
          m_sProtocolVersion.erase();
          m_sProtocolVersion.insert(0, "HTTP/1.0");
        case HTTP11:
          m_sProtocolVersion.insert(0, "HTTP/1.1");
        default:
    variables m_sProtocolVersion are declared as  std::string m_sProtocolVersion;
    Compilation errors:
    d:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\5.4.1\bits/basic_string.h:1659: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_replace(unsigned int, unsigned int, char const*, unsigned int)'
    I read in a forum that it was possible to avoid this by adding a compilation directive but I do not know or put it, maybe in the file platfomr.txt?
    the directive is -D_GLIBCXX_USE_CXX11_ABI=0
    i need to use std::string because is an old program.
    Has someone already had this problem
    i use teensy 3.6 last version and arduino last version.
    Thanks for your help.
    12,177
    not a string user - but a search suggests erase() with no params will NULL the string? And then insert(...) would just attempt to set the string to the supplied value.
    Perhaps just replace the code with: the right variation of :: m_sProtocolVersion = "HTTP/1.0";
    this variation not work
    //Set protocol version
      switch (protocol)
        case HTTP10:
          ::m_sProtocolVersion = "HTTP/1.0";
        case HTTP11:
          ::m_sProtocolVersion = "HTTP/1.1";
        default:
    CHTTP.cpp:105: error: '::m_sProtocolVersion' has not been declared
    CHTTP.cpp:109: error: '::m_sProtocolVersion' has not been declared
    CHTTP.cpp:113: error: '::m_sProtocolVersion' has not been declared
    the problem is the compilator.
    i have test to put at top of file template class std::basic_string<char>; and is a same.
    any idea ?
    12,177
    Is this properly declared before use? : variables m_sProtocolVersion are declared as std::string m_sProtocolVersion;
    yes is declared before use
    int m_iRemoteSrvPort;
        int m_nHTTPLastStatusCode;
        long m_nRcvBufLen;
    i don't untersdand because the code below work
    //Setting url
    void CHTTP::SetUrl(const char* url)
      m_sUrl = url;
    m_sUrl is defined as    std::string m_sUrl;
    may be missing a header include ?
    d:\program files (x86)\arduino\hardware\tools\arm\arm-none-eabi\include\c++\5.4.1\bits/basic_string.h:1243: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_replace(unsigned int, unsigned int, char const*, unsigned int)'
    the problem is a linker std::__cxx11
    I can replace std :: string by String but I wanted to know why std :: string does not work, someone can do a test on two lines of code to know if it works.
    I replaced std: string by String now everything works but I think there is a g++ version problem with c++ 11 parameters CFLAGS in the teensy 3.6 compilation settings at the boards.txt file
    12,177
    Not surprising - possibly by design to limit or control the code that can be included and used for safety here in the generally smaller is better embedded world.
