Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 26 to 50 of 162
Thread: Teensy 4.0 Release
  1. #26
    Aug 2017
    16
    COngratulation. This is awesome. Do you have plan to develop a other board similar to teensy 3.6.
  2. #27
    Processor Details says:
    Teensyduino automatically allocates your Arduino sketch code into ITCM and all non-malloc memory use to the fast DTCM, unless you add extra keywords to override the optimized default.
    Does this mean our sketches are limited in size to what will fit in ITCM rather than the 2M FLASH? And where are these "extra keywords" documented?
  3. #28
    Jun 2016
    rural West Virginia
    61
    I dropped everything and ordered three of them when I got the email from Kickstarter saying BUY NOW!!!! Server struggling? It's dilithium crystals must have melted if everybody got that email at the same time (about 10:30 EST). I couldn't even open the PJRC home page for several minutes, and then I was quite surprised that they were far cheaper than I had thought. I got a tracking number from Robin early afternoon and they should be here by Saturday.
    Has anybody tried hooking one of these (or the beta boards) to the OSH park CS42448 board yet? If not, then I'm going to try.
  4. #29
  5. #30
    10,058
    Quote Originally Posted by Socratease View Post
    To have Code/Data reside on FLASH use : PROGMEM
  6. #31
    20,752
    With the default linker script we're using so far, yes, unless you use the keywords to force code into only the flash.
    If this becomes a serious problem, we'll probably provide an alternate linker script. Not sure how we'll offer than from a UI perspective. The day is still young....
    Does mentioned on this forum count at documentation?
    To force a function or array into flash only, use PROGMEM.
    To force code into TCM (which is currently the default), use FASTRUN. When/if that alternate linker script is published (or if you hack one yourself), you'll want to have FASTRUN on your interrupts and other speed sensitive code.
    Might also be worth mentioning these do nothing on code that is inline optimized. Then the attributes of the function where the code is inlined takes precedence.
  7. #32
    Thanks!
    Hmmm... Awful hard to uncover details in 4k posts, especially if you don't know what keyword to look for. There are a lot of new features and concepts in the M7, it's going to take a while to get familiar with it.
  8. #33
    I was wondering: do we really need a Teensy that's 300 times (!) faster than the original? You could run a complete Linux kernel on this, providing it has sufficient RAM and Flash.
  9. #34
    Mar 2013
    128
    YES. There is SO much interesting audio and music code which requires double precision floating point.
  10. #35
    Just ordered 5pcs.
    Quote Originally Posted by TFTLCDCyg View Post
    One question: Which microSD socket do you recommend to use?
    Ditto!
  11. #36
    3,356
    It´s alive!!!!
    Congratulations for the hard work!.
    Any link?
    This post mentions accessing the microSD pins:
    The beta2 board had a flex cable socket soldered in and a flex cable connector (presumably HFW8R-1STE1LF) soldered in.
    Unfortunately, it looks like the HFW8R-1STE1LF is at the end of life. Digikey no longer stocks it, and Mouser only has 255 on hand.
  12. #37
    10,058
    RE_ SD socket ... "There is a set of 8 pads that are spaced at .1mm, that is setup to allow you to solder on a ribbon connector"
    This link has parts linked to digikey :: pjrc.com/threads/57111-Teensy-4-0-MicroSD-Socket
    ** LINK FIXED
  13. #38
    3,356
    Ummm, that link isn't correct. I believe this is the link:
  14. #39
    DigiKey says they have 495 of those connectors. https://www.digikey.com/products/en?keywords=AE11351-ND
    And the pin spacing is 1mm, not .1mm.
    I think you'd need memory mapping and protection to run Linux. Have to get to the ARM Cortex-A chips for that.
  15. #40
    Jun 2016
    6
    Thanks for the part links! One more question - pins 24-33 are also SMT pads. Are they 2.54mm pitch, and spaced correctly for this part?
    https://www.digikey.com/product-deta...7459-ND/614775
    (Or, is there already a preferred part for this?)
    Thanks again!
  16. #41
    Apr 2013
    142
    Quote Originally Posted by bigpilot View Post
    What a beast
  17. #42
    Junior Member liamtmlacey's Avatar
    Jul 2016
    Bristol, UK.
    6
    Congratulations - I’m really excited about this! Will it be shipping to your worldwide distributors soon (UK in particular)?
  18. #43
    Dec 2018
    18
    Explain to me again the meaning of this word 'need'...
    My ShapeOKO CNC router is controlled by an Arduino UNO running GRBL. That is 32KB of very, very tightly packed code. There's literally NO room left. It can do 30.000 steps/second and control 3 axis.
    With a Teensy, it would be possible to add a 4th, 5th or even a 6th axis, tool width compensation, backlash compensation, a LCD and buttons for jogging and start/stop, program selection, macros... and even let it cut at higher speeds...
    (30K steps may sound much, but we're running 16microsteps x 400step/rev motors. A theoretical top speed of 750mm/second... )
    Not that GRBL will have an official Teensy port capable of taking advantage of the extra power, though.
    (Not without a driver shield, at least)
    My Resin 3D printer(Kudo3D Bean) have both an Arduino(used to lift and lower the printing platform only) and a Raspberry Pi to control the LCD and handle the web interface.
    There's no reason why a Teensy 4.0 shouldn't be able to do the job of both of those.
    (If a Parallax Propeller chip can run a web server, google 'Parallax spinneret' sadly discontinued, why shouldn't the Teensy be able to do it?)
    Even an ESP8266 can act as a simple web server these days.
    Make a faster controller, and someone will find a use for it.
  19. #44
    20,752
    Quote Originally Posted by Sanworks View Post
    Yes
    That part looks like it should fit nicely.
  20. #45
    20,752
    Quote Originally Posted by liamtmlacey View Post
    Yes. In fact, it already has. We sent Teensy 4.0 inventory to several distrubutors on Monday & Tuesday. That's why Adafruit, Sparkfun and (maybe) others had it in stock today. As I recall, there were a several packages that went to non-US distributors. So you should start seeing it appear in Europe pretty soon.
    Looks like Pimoroni already has a page.
    https://shop.pimoroni.com/products/t...elopment-board
    I don't see anything yet at http://www.hobbytronics.co.uk, but they are the other UK company that I believe should get it soon.
    Maybe Robin will notice this thread and give us better info....
  21. #46
    Finland
    133
    What I'm thinking of, is a controller for 3D printers using a carrier board with TMC2208 support, and proper isolation between motor ground and logic ground, using e.g. Si86xx isolators. (Lack of isolation really bugs me with current carriers.)
    Teensy 4.0 is beefy enough to handle cubic curve interpolation, and has enough memory for a proper path planner. I don't think any slicers support cubic/Bézier curves yet, but when they do, I bet it'll make a nice difference in curved surfaces.
    I'm waiting for Mandu to get some in stock; shipping and customs is too much hassle for me
  22. #47
    Senior Member fms1961's Avatar
    Jul 2015
    Northern Germany
    154
    Congratulations to you new masterpiece, Paul! I hope it will be available in germany soon ... (EXP-TECH or Watterott I presume ...) Due to my daily professional work I switched to Mongoose OS and ESP32, but maybe I will be able to use the Teensy as a core controller for an APA102 LED project, which I then will be controlled via ESP32 under Mongoose OS. Are there any other frameworks that I can use to program the Teensy? Because the word "Arduino" is a no-go for professional customers ...
  23. #48
    Excellent! We do a lot of one-off prototyping and random digital component testing around here and the Teensy 3.1, 3.2, and 3.6 have been heavily used for these purposes. I am really looking forward to getting our 4's delivered. Question -- will I be able to do byte-sized GPIO operations with a single command like I could on the 3's using the native microcontroller functions? It was great being able to do that and optimize for speed (including inline ASM) while still working in the simple Arduino IDE. It looks like there is not a full byte-aligned set of GPIO from the same port available on this device, but maybe there's another way to make it work with some clever masking? Thanks!
  24. #49
    New York
    4,269
    TEENSY 4 - CMSIS-NN(Neural Network)
    Out of curiosity I wanted to see the performance of using the ARM-CMSIS-NN (Neural Network) library versus the Teensy 3.6. For those of you who don't know one of the examples is a image classifier using the CIFAR-10 dataset. Hacking up the example to display on a ILI9341 (240x320 display) the performance is:
    T4 - 71 milliseconds
    T3.6 - 446 milliseconds @180Mhz
    Here are a couple screen shots. The image is only 32x32:
    Teensy 4.0
    Teensy 3.6
    This is just a demo of the possibilities with the Teensy 4.0
  25. #50
    Very Cool Stuff. Is there a specific data sheet for the 1062, or is the 1060 or 1064 the same except for flash size? Any thoughts on making an extended version with more of the peripherals broken out? Ethernet, LCD drive, camera etc?
