Results 1 to 5 of 5
Thread: Eighty One KHz
    Mar 2015
    UK
    300
    Eighty One KHz
    I had need recently to see if I could generate a very precise 81 KHz signal using a Teensy 3.5. I was looking for precision much better than 1 Hz.
    This frequency is employed by Radio Station GYN2, which co-incidentally happens to have the tallest man made structure in the UK - an antenna with a height of 365 metres.
    81 KHz is a very unusual frequency to create from a Teensy. The peripheral clock frequency of 60 MHz does not lend itself kindly for driving an FTM timer by a simple direct division ratio.
    After a few experiments, I found that the best way to do this was to use the "dither" principle, which entails hopping from a frequency just below 81 KHz to another just above 81 KHz and back again (ad infinitum). If this switching is done fast and at the correct rate, then the "average frequency" of a Teensy square wave can be made to appear to be a very precise 81 KHz. This "dithering" will create some jitter on the generated signal edges, but if this jitter is acceptable then the problem can be solved in this way.
    The project code for this experiment is included below. I use the dither switching in two distinct ways. First, to switch the MODULUS of timer FTM0 between two adjacent values, and second to switch digital capacitors that control the Teensy 16 MHz crystal itself. The first is a form of coarse frequency adjustment, and the second is very fine adjustment.
    The dither switching is performed inside the Interrupt Service Routine (ISR) that is fired every time the FTM timer count rolls over from the MODULUS value to zero. By changing the modulus quickly at the start of the ISR, then its register will already have been updated ready for when the counter needs to make the value comparison at the top end of the count. I use Channel 2 of the FTM0 timer for my own convenience, but another channel could easily be used instead.
    To allow for dynamic adjustments, I can enter values for the switching points (on a scale of 0 to 999) by entering keystrokes via the serial monitor. For example, typing "i500<CRLF>" will set the ISRCount at 500, which is mid scale for the MODULUS factor. Typing "i501<CRLF>" will nudge the frequency upwards slightly, or "i499<CRLF>" will nudge it downwards.
    Using a GPS signal as a reference, and typing new values by trial and error, then the 81 KHz output frequency can be gently nudged to be better than 1 Hz. Similarly, by typing "x500<CRLF>" etc. then very fine adjustments can be made way less than 0.1Hz.
    The picture shows just how good this technique works (but you can't see the jitter). My scope frequency counter is in known error by 1 part in 10e5, so that "8" on the end of "81.0008 kHz" is actually correct.
    When dealing with extreme precision of this nature, it has to be remembered that control will be temperature dependant. Don't expect to set the frequency exact on one day, and find it the same the next day. But it won't be far off
    //Teensy35 - Eighty One KHz Experiment
    //Date: Mon 05 AUG 2019 - Experiments with precision 81 KHz (version 02)
    //CPU speed 120 MHz = 60 MHz Peripheral Clock speed (16.667 nS cycle).
    //Uses Teensy 3.5. FTM page in Reference Manual - Page 783.
    //K64 Signal Multiplexing - Para 10.3.1 Page 246.
    //Require two cycles of FTM0 for one cycle of 81 KHz, hence "then divide by 2" in modulus calculations
    //Declarations
    #include <stdint.h>
    volatile unsigned int FTM0MODA, FTM0MODB, ISRCount, ISRAdjust, XtalCount, XtalAdjust, OneSecCount;
    byte Byte1, Byte2, Byte3, Byte4;
    boolean Toggle;
    //Set Up routine
      Serial.begin(9600);             //setup serial port
      //initialise Flextimer 0
      FTM0MODA = 369;       //369 = 370 - 1 (1st Modulus for FTM0). 60,000,000 divided by 370 and then divided by 2 = 81.081081 KHz
      FTM0MODB = 370;       //370 = 371 - 1 (2nd Modulus for FTM0). 60,000,000 divided by 371 and then divided by 2 = 80.862534 KHz
      FTM0_MODE = 0x05;     //set write-protect disable (WPDIS=1) bit to modify other registers. FTMEN = 1.
      FTM0_SC = 0x00;       //set status/control to zero = disabled (enabled in main loop)
      FTM0_MOD = FTM0MODA;  //set modulus to initial value
      FTM0_C2SC = 0x14;     // CHF=0, CHIE=0 (disable interrupt, use software polling), MSB=0 MSA=1, ELSB=0 ELSA=1 (output compare - toggle), 0, DMA=0
      FTM0_C2V = 0;         //compare value = 0 for CH0
      PORTA_PCR5 |= 0x300;  //MUX = alternative function 3 gives FTM0_CH2 = toggle output on Teensy Pin 25
      //enable FTM interrupt within NVIC table
      NVIC_ENABLE_IRQ(IRQ_FTM0);
      //lower Systick priority and raise IRQ_FTM priority
      SCB_SHPR3 = 0x20200000;             //Systick = priority 32 (default was zero - highest priority)
      NVIC_SET_PRIORITY(IRQ_FTM0, 0);     //raise FTM0 IRQ to priority 0
      //enable external clock on FTM0, no prescale
      FTM0_SC = 0x48;       // (Note - FTM1_SC [TOF=0 TOIE=0 CPWMS=0 (Up Counting only) CLKS=01 (Peripheral Clock) PS=000 (no prescale divide)]
      //initialise variables
      pinMode(13, OUTPUT);    //pin 13 (LED) as digital output
      ISRCount = 0;
      XtalCount = 0;
      XtalAdjust = 500;
      ISRAdjust = 629;
      FTM0_MODE = 0x04;       //FTMEN = 0 (cannot alter FTM0_MOD inside ISR when FTMEN = 1)
    // ISR routine for FlexTimer0
    //(Triggered by FTM0 timeout on each Cycle)
    //FASTRUN puts this code into RAM to run twice as fast
    //Serial Monitor: type i123<CRLF> to set ISRAdjust to "123", type x123<CRLF> to set XtalAdjust to "123"
    FASTRUN void ftm0_isr(void) {
      //ISR latency time = 200 nanoSecs after interrupt flag set by FTM1 Timer Overflow
      FTM0_SC &= ~FTM_SC_TOF;             //clear overflow flag
      //test which FTM0_MOD value to use - dither between these two values to get exact 81 KHz output frequency from FTM0 toggle output
      if (ISRCount<=ISRAdjust) {
        FTM0_MOD = FTM0MODA;              //higher output frequency (81.081081 KHz)
      if (ISRCount>ISRAdjust) {
        FTM0_MOD = FTM0MODB;              //lower output frequency (80.862534 KHz)
      //update ISR counter (dither scale 0 to 999)
      ISRCount++;                         //increment ISRCount
      if (ISRCount>=1000) {               //counter beyond max value (999)
        ISRCount = 0;                     //therefore reset ISRCount
        OneSecCount++;                    //also, increment one sec counter
        if (OneSecCount>=162) {           //162 is twice 81 (KHz), so times 1000 gives a one second pulse
          OneSecCount = 0;
          Toggle = !Toggle;
          digitalWriteFast(13, Toggle);   //blink the LED on/off every second
      //This following code will make incremental frequency adjustments circa 1Hz and below (on a scale 0 to 999)
      //adjust peripheral clock freq via digital capacitors if reached XtalAdjust value
      if (XtalCount<XtalAdjust) {         //counter reached point to change digital capacitor
        OSC0_CR = 0x04;                   //faster digital capacitor setting (0x04 = +26.661 ppm)
      else {
        OSC0_CR = 0x02;                   //slower digital capacitor setting (0x02 = -3.109 ppm)
      //update XtalCount (dither scale 0 to 999)
      XtalCount++;                        //increment XtalCount
      if (XtalCount>=1000) {              //counter beyond max value (999)
        XtalCount = 0;                    //therefore reset XtalCount
    //Main Loop
      //read key input (if any)
      KeyInput();                         //read key input (if any)
    //KeyInput Routine
    void KeyInput() {
      //process any keystrokes available
      if (Serial.available()>0) {
        //read the incoming byte
        Byte1 = Serial.read();
        if (Byte1>0x20) {
          switch (Byte1) {
          case 'x':  //x123 - set XtalAdjust
            if (Serial.available()>=3) {
              Byte2 = Serial.read();
              Byte3 = Serial.read();
              Byte4 = Serial.read();
              XtalAdjust = ((Byte2-0x30) * 100) + ((Byte3-0x30) * 10) + ((Byte4-0x30) * 1);
            Serial.print("XtalAdjust = ");
            Serial.println(XtalAdjust);
          case 'i':  //i123 - set ISRAdjust
              ISRAdjust = ((Byte2-0x30) * 100) + ((Byte3-0x30) * 10) + ((Byte4-0x30) * 1);
            Serial.print("ISRAdjust = ");
            Serial.println(ISRAdjust);
          case 'a':  //a123 - set FTM0MODA
              FTM0MODA = ((Byte2-0x30) * 100) + ((Byte3-0x30) * 10) + ((Byte4-0x30) * 1);
            Serial.print("FTM0MODA = ");
            Serial.println(FTM0MODA);
          case 'b':  //b123 - set FTM0MODB
              FTM0MODB = ((Byte2-0x30) * 100) + ((Byte3-0x30) * 10) + ((Byte4-0x30) * 1);
            Serial.print("FTM0MODB = ");
            Serial.println(FTM0MODB);
          } //end of switch statement
         } //end of Byte1 > 0x20
      } //end of if Serial Available
    Mar 2015
    UK
    300
    Having found a solution which was an almost perfect 81 KHz frequency square waveform, I wondered if it was now possible to reduce the jitter without loss of frequency precision.
    The jitter is caused by the "transitions" of the logic levels of the waveform (from low to high, and high to low) being in the wrong time position - in comparison with a "true" 81 KHz waveform (that is, one not using the dither principle, and where the transitions always happen at precisely equal intervals).
    This is illustrated in the "Modulus Schemes" diagram below. Scheme (1) is that employed in the previous code listing, where all the MODA transitions happen in the counter range of zero up to the switching point at the "ISRAdjust" value. It starts at time "x" (ISRCount = 0) and switches over from MODA to MODB at time "y".
    If we refer to the times between transitions as being HALF PERIODS (two halves making up the full PERIOD of the waveform), then you can appreciate that because MODA is the higher frequency (just above 81 KHz), by the time the waveform reaches time "y" then the SUM of all MODA HALF PERIODS causes the maximum deviation in time from where the "true" 81 KHz waveform ought to be. Indeed, time "y" is happening too early and the longer HALF PERIODS of the MODB HALF PERIODS (MODB creates a frequency just below 81 KHz) now compensate to stretch things out in time to the point at time "z" where the dithering waveform exactly reaches the same time point that a "true" 81 KHz would have reached. Now at time "z", the artificial 81 KHz made by Teensy is back in precise time synchronism with a true 81 KHz waveform.
    The NEW IDEA to reduce jitter then suggested itself as being to better "mix up" the MODA and the MODB HALF PERIODS. By mixing the switching from MODA to MODB in a more uniform way (one for one), then that would result in less overall deviation from the "true" 81 KHz waveform transitions. The diagram illustrates this in Scheme (2). However, because there needs to be more MODA HALF PERIODS from "x" to "z" than those of MODB, it inevitably means there will be some MODA ones left over. That is a simple consequence of the math numbers. But it should reduce the jitter.
    The jitter measured in Scheme (1) was a maximum of around 3.8 uSecs. This is quite a lot - the overall period of an 81 KHz waveform is 12.346 uSecs. When I tested the coding for Scheme (2), I found that the jitter had reduced by about a half, now down to 1.8 uSecs. A good result and a big improvement for Scheme (2) over Scheme (1). But it still niggled me that there was an excess of MODA HALF PERIODS tacked on to the end of the Scheme, and I wondered if I could "bury" these in a further "mixing up" way, to again reduce the total amount of jitter.
    Thinking this over in bed last night, I began to mentally switch from a single MODA time (which I calculated would transit about 6 nanoSecs too early) to then adding a single MODB (which would transit 10 nanoSecs too late). So summing these together, it would result in the transition time going from -6nS absolute, to +4nS absolute. So add another MODA - that results in -2nS absolute. Now the tricky part. Don't add MODB, but try another MODA. That makes -8nS absolute. Now add the MODB to make +2nS abs. Next another MODA for -4nS. And then another MODA for -10nS abs. Finally, add a MODB and this should be somewhere around 0nS abs.
    Hmm. Interesting. This suggests a Scheme (3). And if the absolute value of the overall deviation time of 0nS is to be believed, then repeating this ad infinitum should give a new 81 KHz waveform which not only is a very precise frequency, but it should have very little jitter as well. The theory suggests that the absolute jitter should be no more tham -10 nS (early) and only +4nS (late). And any overall discrepancy in the precise frequency arising from this new Scheme (3), ought to be able to be compensated by the fine adjust of the Teensy crystal using dithering of the digital capacitors. I will put the results of Scheme (3) in another post to make this more readable...
    Mar 2015
    UK
    300
    So the Scheme (3) with absolute timing is as follows, recalling that MODA is 6 nS early, and MODB is 10 nS late:
    MODA (-6nS), MODB (+4nS), MODA(-2nS), MODA(-8nS), MODB (+2nS), MODA (-4nS), MODA (-10nS), MODB (0nS).
    These are single HALF PERIODS of the waveform and when the Scheme end is reached, it is then repeated over and over to make an artificial 81 KHz. Each HALF PERIOD is one pass of the ISR routine, with the modulus being switched in the sequence presented by the scheme.
    The coding for this within the ISR is to replace the first part of the previous ISR listing with what follows. I introduce a new variable to the volatile unsigned integer list of "ISR8Count":-
      ISR8Count = (ISRCount%8);
      if (ISR8Count==0) {
        FTM0_MOD = FTM0MODA;  //-6nS
      if (ISR8Count==1) {
        FTM0_MOD = FTM0MODB;  //+4nS
      if (ISR8Count==2) {
        FTM0_MOD = FTM0MODA;  //-2ns
      if (ISR8Count==3) {
        FTM0_MOD = FTM0MODA;  //-8nS
      if (ISR8Count==4) {
        FTM0_MOD = FTM0MODB;  //+2nS
      if (ISR8Count==5) {
        FTM0_MOD = FTM0MODA;  //-4nS
      if (ISR8Count==6) {
        FTM0_MOD = FTM0MODA;  //-10nS
      if (ISR8Count==7) {
        FTM0_MOD = FTM0MODB;  //-0nS
      //(... same as previous...)
    The results from Scheme (3) were spectacular in the reduction of jitter. I include now three scope pictures which were taken using a gps reference 81 KHz waveform on trace 4 (Blue). The pictures left to right are Scheme (1), Scheme (2), Scheme (3). The Teensy generated artificial 81 KHz is trace 3 (purple). The third picture confirms the theory in my previous post that the jitter is reduced to about 14 nS total. A very pleasing result, to think that this waveform also has a frequency precision to better than a tenth of 1 Hz.
ID:	17166 Click image for larger version.
ID:	17167 Click image for larger version.
    Mar 2015
    UK
    300
    I forgot to add that in order to get the 81 KHz frequency exact with Scheme (3), I needed to change the value from 0x04 to 0x08 for one of the digital capacitors...
        OSC0_CR = 0x08;                   //faster digital capacitor setting (0x08 = +48.172 ppm)
      else {
    This then allowed the value of "XtalAdjust = 665;" which brought the waveform display stationary compared to gps in picture 3.
