Results 1 to 5 of 5
Thread: Pin 30 not working on Teensy 3.2
    Aug 2019
    3
    So, I bought Teensy 3.2 and everything works fine except for pin 30. Digital write does nothing and analog read gives me values like anything isn't connected. Why is this a problem? Any help would be appreciated.
    20,459
    I can't say why it's not working for you, but I can confirm it does indeed work if you run this code and connect a LED+resistor.
      pinMode(30, OUTPUT);
      digitalWrite(30, HIGH);
      digitalWrite(30, LOW);
    The LED definitely does blink. Here's a photo.
    Aug 2019
    3
    I've tried and it's simply dead all surrounding pin do indeed seem to work.
    Oct 2012
    Portland OR
    660
    I suspect it's possible to kill a single pin with the rest of the chip still OK, by destroying that pin's output buffer, for example by a large enough ESD hit.
    EDIT: You can also get the same effect with one bad solder joint on the chip's pin, which you could confirm if you have steady hands and a fine enough probe.
    Aug 2019
    3
    I guess you are right but it could be also bad solder joint at that pin on chip.
