Page 17 of 17 FirstFirst ... 7 15 16 17
Results 401 to 418 of 418
Thread: Teensy 4.0 Breakout Kit
  1. #401
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    129
    I'm no expert, but after some trial I set the temp to 20 degrees c above the solder paste temp and leave the flow low. Remains to be seen if I'll damage the gun that way, the temp is at the low end of the gun's range so...I'm guessing it should last. If not, oh well... another fee paid towards learning. $40 gun off of Amazon.
    I've done some test work with the pre heater and without, with good results either way...I reckon the potential warping of a circuit board goes hand in hand with the size.
  2. #402
    5,318
    Quote Originally Posted by ETMoody3 View Post
    I picked up one of these years ago and used it maybe twice: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1. Maybe its time to pull it out again and figure out how to use it.
  3. #403
    May 2016
    245
    A bit off topic but if you are want to improve your soldering skills, here's a video showing the SMD assembly of a new Russian SDR (software defined radio) kit. It's not a tutorial, but it shows all the SMD soldering techniques in action (including the drag method and hot-air reflow on some very large ICs). It's interesting to see how the surface tension actually drags the chips and aligns the chips. The guy is super fast! Unfortunately the commentary is in Russian. Later in the video it shows the completed SDR in action which (to me) is also impressive.
  4. #404
    Mar 2014
    New Ulm, Mn
    129
    I decided I wanted to try a breakout on a project so I went ahead and did this much assembly...no CAN bus parts, no pull ups. I used solder paste and a heat gun. Small bits of copper tape were used to hold down the flex cable. As soon as I finish the through hole soldering I'll report on testing. I did check for shorts and continuity. So far so good.
ID:	18816Click image for larger version.
ID:	18817Click image for larger version.
ID:	18818Click image for larger version.
ID:	18819Click image for larger version.
ID:	18820Click image for larger version.
ID:	18821Click image for larger version.
ID:	18822Click image for larger version.
  5. #405
    Mar 2014
    New Ulm, Mn
    129
    Yup, everything works. USB Host worked with every device tested.
  6. #406
    11,756
    Good job, I think I posted I built one of the second betas to work. Just used a hand iron and solder wire this time.
    I noticed the 1220 cell on my first Beta board was dead. Since I put headers on wrong/bottom side - pinning it in - I desoldered it - and used the spare NEW style holder (thanks Dan) - snipped off bottom centering pins - soldered one vBat end with Kapton tape under the other end and then jumpered that end to nearby GND pin and it is back in service. Not sure if the unpowered T_4 used up that much power - or if the cell started weak?
  7. #407
    Mar 2019
    2
    Is there a reason why you use a flex cable over 1mm pitch right angle headers for the pads on the underside of the teensy?
    It seems like a lot more work and cost to using this flex cable.
  8. #408
    Feb 2020
    5
    Hi Guys,
    Is this T4 breakout available to buy as a kit yet ?
    If so can someone please post a link ?
    Cheers
    Jay
  9. #409
    Mar 2020
    4
    Hi guys,
    Any news on this breakout board?
    Miloš
  10. #410
    178
    Quote Originally Posted by Miloš View Post
    Yes, the first run of boards are being assembled now.
    The production time has been delayed because of the virus outbreak in China.
    The current estimate is that they'll be ready in about 30 days.
  11. #411
    Mar 2020
    4
    Nice, thanks for the info. Does that mean that we will be able to order the kit via your website on Tindie? Will you offer kits with Teensy 4.0 included?
    Miloš
  12. #412
    178
    Yes, and yes!
  13. #413
    178
    At long last: https://www.tindie.com/products/19936/
    Don't forget to use the code PJRCFORUM25 to save 25 percent!
    Please accept my apologies for all the delays. First, the pandemic delayed SMD assembly in China significantly. Then it rendered my workshop and storage space here in the United States inaccessible. We're still under lockdown here in Massachusetts.
    Thank you so much to everyone who assisted with feedback, suggestions, debugging, and beta testing.
    Assembly instructions are still in progress, but will be available at https://talldog.dozuki.com when they're finished.
    In the meantime, you can check out the datasheet.
    Sincerely,
    Dan
ID:	19940Click image for larger version.
ID:	19941Click image for larger version.
ID:	19942Click image for larger version.
ID:	19943Click image for larger version.
ID:	19945Click image for larger version.
  14. #414
    Mar 2020
    4
    Ordered this morning
  15. #415
    11,756
    Very cool you got it all together @loglow/Dan/TallDog ! Bummer on the long delay to get there.
    The Beta I assembled has been one of my active T4's here during testing since you sent it out months back. USB Host and SD card all usable. Will be nice for assembly having the SMD parts pre-soldered on he PCB!
  16. #416
    178
  17. #417
    178
    Yeah, but delays seem to be the normal these days...
    That's great! I so much appreciate your testing. SMD soldering is definitely not for everyone, so I'm very happy to have gone the pre-assembled route.
  18. #418
    Mar 2020
    4
    I got my boards safely yesterday. Starting a new project next week. Thank you so much loglow. Hey, do you plan on releasing the Eagle file for this board?
