Results 1 to 14 of 14
Thread: Bootloader Chip For Teensy 4.0
    Aug 2019
    1
    Will the bootloader chip for the Teensy 4.0 be available for purchase? So I can integrate a Teensy 4.0 directly onto my pcb. I know you can purchase the Teensy 3 bootloader chips but I didnít see the Teensy 4.0 chip on the website. https://www.pjrc.com/store/ic_mkl02.html
    Aug 2019
    4
    I'm also interested in this. Does anyone know the answer?
    Thanks,
    Louis
    Aug 2014
    Surrey, England
    8
    Bump .
    6,354
    Note, If you go up to the PJRC website and try to add something to a shopping cart you will see a message:
    PJRC will be closed November 16 to 24.
    10,961
    At some point the bootloader chip in use that is common to other Teensy models will most likely be released with support for the Teensy 4.0 MCU as well. Paul has not posted anything to the contrary AFAIK
    No idea what the schedule for that may be going forward - but looking back Paul has been fully occupied with PJRC matters like stocking the T4 and other models as well as software for T4 and TeensyDuino update to the IDE 1.8.10 and SerMon support to be generally usable as Serial monitor to the output rate from the T4's 480 Mbps USB.
    21,480
    PJRC will sell a boot loader chip for 4.0, but probably not until at least mid-2020, maybe later.
    Teensy 4.0's bootloader as it exists today does not work with a fresh IMXRT1062 chip, so we can't simply sell you chips with the exact code we're shipping now. That code depends on the 1062's fuses being pre-set by the test fixture we use.
    Eventually I will add code to the bootloader to detect a fresh IMXRT1062 chip and automatically set its fuses. But today that code simply does not exist. And *many* other things, like adding the missing USB device types, are a much higher priority, so you can expect this bootloader work to not happen until at least the middle of next year.
    21,480
    Quick update, if anyone's still watching this thread... today I am working on making the bootloader compatible with virgin IMXRT chips (the chip on Teensy 4.0 gets fuses initialized by our bed-of-nails test fixture).
    Bootloaders need to be tested very thoroughly. We'll probably have 1 month or longer of testing, so please do not expect to see PJRC offering a ready-to-use bootloader chip until March or perhaps April. But it is coming.
    Oct 2015
    Vermont, USA
    209
    Definitely still paying attention to this!
    Thanks for the update,
    Chip
    213
    Paying attention here as well, this would definitely help make my product easier to build.
    Mar 2018
    Brooklyn
    4
    Definitely paying attention to this! Thanks for moving the potential release date up!
    175
    This is great to hear, Paul. I'm eagerly awaiting it! Thanks so much for the update.
    Aug 2014
    Surrey, England
    8
    Awesome! Thanks for the update Paul.
    Dec 2018
    9
    Looking forward to this.
    Mar 2020
    1
    Definitely looking forward to this! Paul, will you be making an announcement when the new bootloader is available?
