Results 1 to 2 of 2
Thread: Why are there duplicate pins grayed out on the Teensy 4.0 pinout cards?
    Aug 2019
    2
    From what I can tell there are only 4 pins like this, and I don't see an explanation for them anywhere on the pinout cards:
    CTX1 is in normal font on pin D22, and also in a lighter gray font on D11
    CRX1: D23 -> D13
    RX5: D21 -> D38
    TX5: D20 -> D39
    Why are these pins in particular duplicated?
    9,033
    That is the normal method of indicating an 'Alternate pin function' going back to the Teensy 3.x cards.
    Where a pin has one or more primary functions the text for the bus/use 'type' is solid black font.
    When a pin can be used - through software specification - to fully support as an Alternate/replacement to the primary pin it is indicated in the lighter grayed font.
