Hi all, after long time without a sign from me I will give you an update of what I have so far:
I used the time do the development and repeated testing of a secondary bootloader and a releated host tool, which are now working stable and reliable even some security features are not yet implemented. After having a look at the bootloader code provided by NXP and trying to understand how it needs to be adjusted to get it work on UART for several days I found it too complex to go this way further. As I already had begun development of a flash bootloader for another processor I decided to work on that and imlplement one from scratch. Meanwhile I had several difficulties with the one or another issue, so it took actually more time than I had expected.
Anyway, its now working and it's time to get the focus back on the security topics.
During the time I also wrote a perl script that helps to generate the configuration file for NXP's Code Signing Tool (CST).
So I will share the code as soon as I have an idea how. That's because I used for the development a different environment than the arduino. My development environment is based on a bunch of Makefiles and has several dependecies on external tools. But the most dogy is, that it also contains other projects. So I do not yet have a good idea how to cut out the relevant part in a way that gives you the possibility to rebuild and use it. So I think I will at least share the plain source code and Makefiles where possible. Maybe someone here who's probably more experienced with arduino comes up with a good idea how to get it into the arduino environment or how to get a build environment prepared for the community.
Great you are back to look into the security topic!
BTW for anyone who hasn't seen it on this third thread Paul posted this - the currently 'not SECURE capable' but bootloader no locking fuses is available in 'test' quantities:
After it gets some confirming feedback Paul noted the order limit will be removed.
Also noted the code on that chip with unlocked fuses will ideally be updatable (by PJRC) for use when the security issue is resolved ... that is on another thread.
In fact I've never been away. But it took me some of my spare time to get prepared for further investigations. BTW nice to see what Paul did in the meantime.
As I understand the, update process, the bootloader is injected into the iMXRT via JTAG by the MKL02 chip. So as long as you do not disable or protect JTAG access this way will still work. Only, once security is enabled, your flashed application image will not be allowed to execute from power-up (by HAB) if not properly signed. Anyway, if one wishes to have a really secure device one will also disable JTAG access, which then excludes further updates in the known way.
Hello everybody,
I made an attempt to set one of the unlocked teensy boards to closed configuration after having burnt the SRK hash fuses and successful HAB authentication in open configuration. But rather undexpectedly the board didn't answer anymore after reset. After long second thought what mistake I might have made and what I should do different, I decided to do the same steps at my MIMXRT1060-EVK with the difference that on this board I'm able to get into the running software via JTAG Debugger. So the result was quite similar right after programming the signed bootloader image via debugger. Anyway, I was still able to debug the code an step/jump arround and inspect memories and registers. First idea was to check the watchdogs and indeed they where enabled. Later it turned out, that this is the proper behaviour and when the image gets authenticated successfully, they are turned off by the HAB before the image starts to execute.
Somhow I managed to send a command via UART into my bootloader to evaluate and dump the HAB status and this is what I got:
According to High Assurance Boot Version 4 Application Programming Interface Reference Manual, Page 57, the 3rd to last line of the hex dump of the events show the following SNVS registers:Code:Hello FBL FBL>habStatus HAB Configuration: 0xcc (closed) HAB State: 0x66 (non-secure) ----- HAB Event 1 ----- Event Data: 0xDB 0x00 0x2C 0x43 0x33 0x30 0xE1 0x1E 0x00 0x00 0x00 0x00 0x80 0x00 0xBB 0x00 0x80 0x00 0x00 0x02 0x00 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Tag: 0xDB -> EVT Len: 0x002C -> 44 Bytes Par: 0x43 -> HAB Ver: 4.3 Evt Status: 0x33 -> HAB_FAILED Evt Reason: 0x30 -> ENGINE_FAIL Evt Context: 0xE1 -> ENTRY Evt Engine: 0x1E -> SNVS ----- HAB Event 2 ----- Event Data: 0xDB 0x00 0x2C 0x43 0x33 0x30 0xE1 0x1E 0x00 0x00 0x00 0x00 0x80 0x00 0xBB 0x00 0x80 0x00 0x00 0x02 0x00 0x00 0x00 0x20 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Tag: 0xDB -> EVT Len: 0x002C -> 44 Bytes Par: 0x43 -> HAB Ver: 4.3 Evt Status: 0x33 -> HAB_FAILED Evt Reason: 0x30 -> ENGINE_FAIL Evt Context: 0xE1 -> ENTRY Evt Engine: 0x1E -> SNVS No more HAB Events found!
Inspecting the very same registers via JTAG debugger shows like the hex dump, that the HP Security Violation Status Register (HPSVSR) has Security Violation 1 set, which according to Security Reference Manual for the i.MX RT1050 Processor, Rev. 1, 04/2018, Page 50 is linked to SJC JTAG active. Obviously this security violation cannot be disabled, just configured as fatal or non-fatal violation.If an entry, exit or test operation fails, an audit event is logged with status field HAB_FAILURE, reason field HAB_ENG_FAIL, engine field HAB_ENG_SNVS and data field containing the following registers (in order):
o HP Security Violation Control
o HP Status
o HP Security Violation Status
o LP Control
o LP Master Key Control
o LP Security Violation Control
o LP Status
o LP Secure Real Time Counter MSB
o LP Secure Real Time Counter LSB
Later I did a power-on reset on the EVK and I was very surprised to see the proper prompt of the bootloader image on the terminal. So what happened? By powering off the board, the JTAG connection was killed and the HAB obviously successfully authenticated the bootloader image. Experimenting with the running image confirmed the suspicion that a connected JTAG might be the reason for the failed authentiation. Here is the HAB status after power-on reset (1) and after re-attaching the JTAG debugger on the EVK board:
Code:Hello FBL FBL>boot Enter FBL FBL>habCheck ROM-Boot ok. FBL>habStatus HAB Configuration: 0xcc (closed) HAB State: 0x99 (trusted) No HAB Events Found!As you can see, after attaching the JTAG debugger, the HAB state changes from "trusted" to "fail_soft" and this is a reproducable issue.Code:FBL>habStatus HAB Configuration: 0xcc (closed) HAB State: 0xcc (fail_soft) No HAB Events Found!
So my assumption for the teensy now is, that due to the JTAG access by the MKL02 chip the SNVS asserts a security violation already while the ROM bootloader is running and so the HAB fails due to security checks as seen in the very first terminal output.
What can be seen on the teensy is, that the Halfkay injecttion via JTAG is still working. So when I shortly press the push button, I'm able to program another image, but obviously this doesn't run because of the reboot following the reprogramming. Also due to the failed HAB authentication the teensy switches to serial download mode, which might be a last resort to un-brick this board. Until now I was not able to get any useful information out of the "bricked" teensys by the sdphost tool as it repeatedly answers with status "HAB enabled" and no reasonable value returned.
So I'm writing this here the in order to possibly get some confirmation or feedback for my assumptions befor I may brick another unlocked teensy in the attempt to disable JTAG access before setting it to closed configuration. Especially I'd like to get confirmed, that the MKL02 chip is connecting to the IMXRT on every reset, not just after pressing the push button, which would further proof the assumption that the reason for the failed authentication is the JTAG connection.
A question here is, if there is a way to temporarily prevent the MKL02 to JTAG the IMXRT after reset. A further question is whether the MKL02 will still apply the necessary signals to let the IMXRT run, if the JTAG connection doesn't due to disablement. A 3rd question is, whether there is a way to tell the Halfkay to directly jump to an address instead of resetting the chip, when it has programmed an image.
Does anybody know how to prevent HAB checking the SNVS status registers or disable SNVS during boot? The latter is implied in a note in the HABv4 API RM:
Note: If a failure occurs when the SNVS is not enabled then the audit event reason field is HAB_WARNING rather than HAB_FAILURE.
Probably just Paul can give substantated answers to those 3 questions...
So please Paul, if your time allows, please let me know whether the Teensy 4.0 will boot and run also if JTAG between MKL02 and IMXRT is disabled. I don't want to brick a fresh non-locked Teensy for finding out that this way might not work, if probably you can give me the answer in advance.
Hello everybody,
here is the latest news about HAB...
As I didn't get a response yet, I started experimenting with a fresh board. So tried to hardly pull up/down single wires of the JTAG interface by which I was able to prevent the MKL02 form accessing the IMXRT, but the SNVS security violation remained.
Next I burnt JTAG_SMODE to 0b01 (Secure JTAG) which normally should block JTAG access to the CM7 DP and only allow access to SJC via callenge-response authentication. Result was, that the MKL02 was still able to reprogram the IMXRT and SNVS still reported SV1 (JTAG active).
Next I burnt JTAG_SMODE t0 0x11 (No Debug) which should even block JTAG access through SJC cia challenge-response authentication. Anyway, the result was the same as before: MKL02 was able to reprogram the IMXRT and SNVS still reported SV1 (JTAG active).
In a for now final step I also burnt SJC_DISABLE fuse to 1 which should disable all JTAG access to the processor including boundary scan and indeed the MKL02 is no longer able to reprogram the IMXRT. Unfrotunately the SNVS still reports SV1.
So I do not try to set the IMXRT on this board to secure configuration until I find a way to convince the SNVS to stop complaining about JTAG access. I also started a new thread in the NXP comunity and hopefully get some useful information there.
In conclusion for the time being I'm not able to make the teensy secure, obviously due to the JTAG access by the MKL02.
Ok, I found a reasonable exlanation for the MKL02 still beeing able to access the IMXRT via JTAG when JTAG_SMODe is burnt to 0b01 or 0b11: AN12419 in chapter 2.3 says that additionally the KTE fuse hes to be burnt to have JTAG secure mode work, which I did not. Anyway tos doesn't change anything on the fact that even with fully blocked JTAG the SNVS indicates security violation 1 (JTAG active).
Ok, I took the board, where all the JTAG is blocked now by fuses and as SNVS still reports SV1 I tried to physically block JTAG access. I soldered very thin wires to those pads of the MKL02 which are most probable stimulated for JTAG access (P13 - JTAG_MOD, P8 - JTAG_TCK, P7 - JTAG_TDI, P5 - JTAG_TMS) and tied them hard to GND even with the risk to damage the MKL02 by possible over current.
Anyway, by doing so after power-up the SV1 (JTAG active) was no longer reported by SNVS. Instesd now it reported SW_SV (Software Security Violation) which is probably by the ROM bootloader due to the fact that security configuration is still open, but that's a guess. I'm not really sure. I also tested whether releasing single pins from being tied to GND will have the same result, but this wasn't the case. So it seams that SNVS is tracking signals on those pins and if one looks like JTAG it will report SV1.
Ok, so far so good. Now having a first sign I did the same aproach with that board previously having secured. Unfortunately it still is not willing to start, so it's not quite sure whether there's someting wrong with the image, SNVS still reports SV1 maybe because of JTAG_nTRST which remains because it's directly connected to DCDC_PSWITCH or SNVS reports something different e.g. SW_SV.
As even with the modification previously described the IMXRT didn't boot successfully and because the reason is not obvious, I decided to make an attempt to completely dedolder the MKL02 in order to gain access to the IMXRT's JTAG interface. As I do not own special desolder station for chips, it was not very easy and I succeded only by destroying the MKL02. So here's what left over of the boot chip:
Unfortunately also 3 pads fell victim to my attempt of which one was the JTAG_nTRST/DCDC_PSWITCH so it looked as if I screwed up this board completely. For good luck I found the 100k resistor on the bottom of the board, which connects this wire to GND and I soldered the related wire there and indeed it works. Here''s how the board now lokks:
So in the end I'm now able to access the IMXRT via JTAG, with the result, that still SV1 is reported by SNVS. But searching the HAB log shows also the ENGINE_FAILED entry due to SNVS and this even if I start the board with no debugger attached. Compared to the MIMXRT1060-EVK this would be expected only, if the debugger is already attached during early startup in ROM boot. I will further investigate what's the differnce between Teensy and the EVK an will keep you informed.
Right few minutes ago I tried to check the HAB entry again but watching the memory with the debugger (target was halted) showed randomly changing RAM contents which was a bit misterious. After disconnectiing the debugger from both, the target and my PC and restarting the debug host application I firstly was not able to reconnect to the target. So I billed and reconnected target power to find the reason for the connection failure during this I also tried several combinations of the JTAG_nTRST/DCDC_PSWITCH and JTAG_MOD wire obviously without success. Next I tried to find a way to check whether the IMXRT does really start and checked my USB devices for the serial boot USB HID to appear, but it did not, firstly. At this point I had the JTAG_nTRST/DCDC_PSWITCH wire connected to GND. As I connected it to VCC (3V3) suddenly the desired USB HID appeared. Ok, this was not really unexpected, as the IMXRT normally doesn't start befor the DCDC_PSWITCH goes HI certaint time after power stabilized. Anyway in yesterday's attempts I didn't bother. Afterward I removed the USB cable to proove that the USB HID diappers again, but it didn't! Why? Obviously the IMXRT got some parasitic voltage by a USB-to-UART adapter connected by 3 wires to UART4 RX/TX and GND. Ok, some point to keep in mind! Now again I tried to re-connect the debugger and after a few unsuccessful attepts I checked the error messages which told me that the debugger was trying to connect via SWD. BTW had the same issue yesterday, but didn't remember. Ok, problem identified, problem solved. No I was able to re-attach to the target. Once halted I checked again the HAB log entries but today found something different! The entry was:
Looking up the codes in the HAB API this can be translated into:Code:0xDB 0x00 0x08 0x43 0x33 0x22 0x0A 0x00
Ok, this is no longer the SNVS security violation but a real authentication failure!Code:Tag: 0xDB -> EVT Len: 0x0008 -> 8 Bytes Par: 0x43 -> HAB Ver: 4.3 Evt Status: 0x33 -> HAB_FAILED Evt Reason: 0x22 -> INVALID_ADDR Evt Context: 0x0A -> AUTH Evt Engine: 0x00 ->ANY
So next I inspected again the image vector table (IVT) of the image in the nor flash at address 0x60001000 which had a CSF address of 0x00000000. Which is definately wrong and is a reasonable explanation for the seen HAB log entry. In order to fix this I reprogrammed the flash by the debugger, so that now the CSF address field got a proper address.
Finally testing to run HAB the commandline of my bootloader came up which indicates successful boot now.
Trying to reproduce the HAB log entry of yesterday I found out that it not had to do with the UART, but with how I configured the debug connection settings and how I used the debugger. Yesterday I configured the connection settings to use JTAG_nTRST for a reconnect and as after plugging in the USB into the board the IMXRT did obviously not run because of the missing rising edge on DCDC_PSWITCH, it was first started when I attached the debugger, hence SNVS detected JTAG active.
Today I disabled usage of JTAG_nTRST and thus had troubles to re-connect the debugger, obviously because the IMXRT was not yet running. Giving the wire a manual rising edge and afterwards re-connecting the debugger worked well and because now the processor started before the debugger was attached SNVS couldn't report SV1 during HAB. Anyway, after attaching the debugger SNVS still reports SV1 and SSM state changes form trusted to soft_fail as seen also on the EVK.
