Results 1 to 3 of 3
Thread: Audio-Example WavFilePlayer for Teensy 3.6 not compiling
    Jan 2018
    9
    I tried to compile the example WavFilePlayer.ino 1:1 but it reports only errors:
    I use Arduino 1.8.9 and I have copied the last version into the folder Arduino/libraries/
    I tried the example from my local pc from example-folder and from the Github-Repo. Both did result in the same error:
    Days ago I already played around with the Audio-Library and was successful to compile other examples which use Output-I2S too.
    Perhaps Arduino did an update?
    /Arduino/libraries/Audio/output_i2s.cpp: In static member function 'static void AudioOutputI2S::isr()':
    /Arduino/libraries/Audio/output_i2s.cpp:152:58: error: 'arm_dcache_flush_delete' was not declared in this scope
    arm_dcache_flush_delete(dest, sizeof(i2s_tx_buffer) / 2 );
    Multiple libraries were found for "Audio.h"
    Used: /Documents/Arduino/libraries/Audio
    Not used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio
    Used: /Applications/Arduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
    Not used: /Applications/Arduino.app/Contents/Java/libraries/SD
    Error compiling for board Teensy 3.6.
    Any hint?
    Best Regards
    Erich
    24,293
    Looks like you may have the latest audio lib from github, but not the latest core lib or new enough beta version of Teensyduino.
    Easiest answer is to install 1.47-beta6.
    https://forum.pjrc.com/threads/54711...l=1#post193715
    Jan 2018
    9
    Thx, that fixed it. After installing 1.47-beta6 it compiles well.
    Tank You very much!
    Best Regards
    Erich
