Page 2 of 2 FirstFirst 1 2
Results 26 to 38 of 38
Thread: Teensyduino 1.47 Released
  1. #26
    9,735
    Quote Originally Posted by KE4EST View Post
    Yep that is how I knew.
    Opps - that was to be a question/request to share those lines
    p#14 shows it fail in that code - but going there it wasn't clear why T_3.6 should work as it didn't show #ifdef's for those MCU's?
  2. #27
    5,424
    Yesterday I did find I do have two of those displays(RA8875 from BuyDisplay.com) (one I never did get to work and the other sometimes...) I had the test apps working on T3.6 earlier, but so far nothing showing up on display on T4, with what I think is same wiring...
    How do any of you have them wired? I assume you are configured for 4 wire SPI? Probably using the 8 pin JP1 for SPI? Are you using any pins up in the other parts of connectors, like the Reset pin?
    Power? The one that was working on T3.6 did not have VR on the board, so hooks up to 3.3v Again at times I think I was/am getting brown out on T3.6 (and T4?) Later yesterday, I tried taking a 3.3v DC/DC converter off of older board I had to see if I could rig it to convert the VUSB to 3.3v... Still no display output, but the Adafruit library was able to read register 0 and liked the result...
    Again back to other questions:
    In this case the library being used. is RA8875 not that Adafruit library. Looks like both libraries are installed as part of the install. I am not sure where the RA8875 in the release is coming from. I don't see anywhere where @PaullStoffregen has forked it, so I assume it is coming from sumotoy. Question is which release/version? And if any changes are made, how to get those incorporated? As SumoToy has not done anything in about 4 years... As for release his main page says:
    https://github.com/sumotoy/RA8875 is the latest stable version.
    but: suggests that you use the development branch: https://github.com/sumotoy/RA8875/tree/0.70b11 as it usually contains bug fixes and the like...
    As for Adafruit libraries, the version of Adafruit_RA8875 as part of this build. In this case Paul does have a fork of the Adafruit code base, but it looks like this fork is something like 60 commits behind the Adafruit version. So question again is if changes are needed where to do it? Note the Adafruit one still is derived from GFX and not the SPITFT class under GFX...
    Edit: Side note: looks like the DC/DC converter I salvaged won't work here. My VUSB is showing only 4.6v? Maybe time to try different USB Hub? And the converter I extracted:
    https://www.digikey.com/product-deta...5-5-ND/2259780
    Is good for VIN in the range: 7-36v... I measured no voltage coming out...
  3. #28
    May 2016
    220
    @Paul,
    I just noticed that you asked at the top of this thread for bugs/suggestions related to Teensyduino 1.47 to help with your next go around. I posted a couple of threads in "General Discussion" that might be more appropriate here:
    1) A suggestion that the different versions of arm_math for T3 and T4 be made the same. The T3 copy is still the old 2012 while the T4 version is a 2017 version in which many functions have been deprecated and have warnings not to use them. (I have been manually upgrading arm_math for my T3.6 work with every Teensyduino release since 2017).
    Since you have already done the upgrade now for T4, it seems to make sense to do the same for T3.
    2) A separate (more serious) problem is related to T4 compiler errors when including user-written Audio Library compatible classes, raised by chipaudette here, and resolved fully here, where expanding on a suggestion by KurtE, I found that the problem went away completely by including
    #include "core_pins.h"
    in AudioStream.h
    What I don't understand is why this problem doesn't show up when using standard Audio library classes??? Anyway, it would be good to have the issue fixed properly in the next Teensyduino...
  4. #29
    Mar 2019
    10
    Just received my 2 T4s, good timing
    Sparkfun did not include the pinout cards though
    Quote Originally Posted by reaganr View Post
    so.. it doesnt give me any USB type options: i.e. MIDI, HID. is that intentional?
    The announcement post does say that "USB types other than Serial" are not yet finished and thus not in this release...
  5. #30
    20,579
    Quote Originally Posted by bicycleguy View Post
    If you make a mistake that writes to much to the screen to fast and get:
    'Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space'
    I've been working these last several days to improve the Arduino Serial Monitor performance.
    Today I have a first test.
    https://forum.pjrc.com/threads/54711...l=1#post213248
    Please give this a try on your computer and let me know if you see an improvement?
  6. #31
    New York
    4,106
    RA8875 Sumotoy Lib v0.79
    @KurtE - @defragster - @KE4EST
    Ok folks broke down and got my RA8875 driver board and display from Adafruit. I got it working with the Adafruit library but not the RA8875 sumotoy library. So I downloaded his development branch 0.79xxxx and modified it to work with the T4. Preliminary results from the benchmark sketch:
    screen:800x480 - rotation:0
    Benchmark                Time (microseconds)
    Screen fill              16494
    Test Pixel               29
    Test Pixels              19420
    Text                     3544
    Lines                    85992
    Horiz/Vert Lines         52593
    Rectangles (outline)     265817
    Rectangles (filled)      265269
    Circles (filled)         146734
    Circles (outline)        142969
    Triangles (outline)      21219
    Triangles (filled)       60942
    Rounded rects (outline)  106210
    Rounded rects (filled)   902876
    screen:480x800 - rotation:1
    Screen fill              16494
    Test Pixel               29
    Test Pixels              11661
    Text                     3544
    Lines                    85985
    Horiz/Vert Lines         52589
    Rectangles (outline)     265266
    Rectangles (filled)      265692
    Circles (outline)        142973
    Triangles (outline)      18194
    Triangles (filled)       57942
    Rounded rects (outline)  106243
    Rounded rects (filled)   902635
    screen:800x480 - rotation:2
    Screen fill              16494
    Test Pixel               29
    Test Pixels              19420
    Text                     3527
    Lines                    85989
    Horiz/Vert Lines         52591
    Rectangles (outline)     265275
    Rectangles (filled)      265826
    Triangles (outline)      21217
    Triangles (filled)       60902
    Rounded rects (outline)  106196
    Rounded rects (filled)   902573
    screen:480x800 - rotation:3
    Screen fill              16495
    Test Pixel               30
    Test Pixels              11660
    Text                     3543
    Lines                    85984
    Rectangles (outline)     265717
    Rectangles (filled)      265796
    Circles (outline)        142971
    Triangles (outline)      18200
    Triangles (filled)       57657
    Rounded rects (outline)  106186
    Rounded rects (filled)   902860
    I will make it available if anyone wants to try it out shortly - stay tuned.
    EDIT: Here is the link to the t4 branch for the sumotoy library:
    https://github.com/mjs513/RA8875/tree/RA8875_t4
    He also has a wiki associated with using the lib - found how to use the adafruit display with it.
    EDIT:
    @PaulStoffregen - don't know how to update the RA8875 library that is installed as part of the Teensyduino install?
  7. #32
    Junior Member KE4EST's Avatar
    Nov 2017
    Far Western NC, USA
    13
    Yes, Please.
  8. #33
    New York
    4,106
    Yes, Please.
    Just added the link in post #31. Make sure its the T4 branch: https://github.com/mjs513/RA8875/tree/RA8875_t4
  9. #34
    9,735
    @Paul - does this in platform.txt matter - or is it showing 1.8.5 on this 1.8.9 system for some reason?:
    # http://www.pjrc.com/teensy/teensyduino.html
    name=Teensyduino
    version=1.8.5
  10. #35
    Sep 2019
    3
    Just got my 4.0, ran the Adafruit SSD1306 demo on it. WOW fast, can almost not see the "animation"! Can't wait for the additional USB support. Thanks!!
  11. #36
    Just received my Teensy 4.0. Looks interesting but can't do much yet. Is there any information out there yet on the specs of the audio implementation on the board or how to get the audio card going with it? Fingers crossed that we get better and more centralized documentation for this potential gem. I wound up giving up on my 3.6 synth project and now have half of an analog modular synth up and running still, it would be great to get a decent compact and portable v4.0 based system going. Looks good so far at this early stage. 'Onya Paul!
  12. #37
    2,198
    Quote Originally Posted by RogerD View Post
    lots of posts on T4 audio ... maybe try this one https://forum.pjrc.com/threads/57764...dio-processing
    I think the T4 version (Rev D) of the audio shield is now available at PJRC store
    https://www.pjrc.com/store/teensy3_audio.html
  13. #38
    Unfortunate that the pin allocation was re-arranged. I'll just have to bodge up an adapter. What I am most curious about are the numerous "Digital audio" pins on the board pinout map and in what way they are implemented.
