Results 1 to 3 of 3
Thread: Xplane Control Panel
    Aug 2019
    2
    Hi all,
    I thank you in advance for any help you can give me on this project. Click image for larger version.
Name:	Xplane Panel.jpg
    At the moment the Com and Nav buttons haven't been programmed. For the rest, they all function individually, until the Battery and Alt switches are on, then only the fuel pump, Avionics, gear lever and encoders work. There seems to be something locking out the code for the other switches once they are on.
    I have gone back bit by bit but come up with the same issue each time.
    I am really new to this coding and have a Teensy 3.6 to run everything. I'm hoping someone will be able to read my code and see the problem.
    Thanks again for any and all input.
    #include <Bounce.h>
    #include <Encoder.h>
    // Input from hardware
    Encoder vor1Encoder(16, 15); // vor1 encoder on pins 15 and 16
    short vor1EncoderPrevious = 0;
    Encoder vortwoEncoder(14, 13); // vor2 encoder on pins 13 and 14
    short vortwoEncoderPrevious = 0;
    Encoder adfEncoder(39, 38); // adf encoder on pins 38 and 39
    short adfEncoderPrevious = 0;
    elapsedMillis vor1EncoderClickInterval = 0;
    elapsedMillis vortwoEncoderClickInterval = 0;
    elapsedMillis adfEncoderClickInterval = 0;
    // OUTPUT //////////////////////////////
    const int greenLeftPin = 25;
    const int greenNosePin = 24;
    const int greenRightPin = 26;
    const int gearSwitchPin = 12;
    const int redLeftPin = 28;
    const int redNosePin = 27;
    const int redRightPin = 29;
    const int fuelpumpLEDPin = 23;
    const int beaconLEDPin = 22;
    const int landingLEDPin = 21;
    const int taxiLEDPin = 20;
    const int navLEDPin = 19;
    const int strobeLEDPin = 18;
    const int pitotLEDPin = 17;
    const int com1LEDPin = 32;
    const int avionicsSwitchPin = 2;
    const int flapsupSwitchPin = 11;
    const int flapsdownSwitchPin = 10;
    const int alternatorSwitchPin = 0;
    const int fuelpumpSwitchPin = 3;
    const int batterySwitchPin = 1;
    const int beaconSwitchPin = 4;
    const int landingSwitchPin = 5;
    const int taxiSwitchPin = 6;
    const int navSwitchPin = 7;
    const int strobeSwitchPin = 8;
    const int pitotSwitchPin = 9;
    Bounce gearSwitch(gearSwitchPin, 5);
    Bounce avionicsSwitch(avionicsSwitchPin, 5);
    Bounce flapsupSwitch(flapsupSwitchPin, 5);
    Bounce flapsdownSwitch(flapsdownSwitchPin, 5);
    Bounce altSwitch(alternatorSwitchPin, 5);
    Bounce fuelpumpSwitch(fuelpumpSwitchPin, 5);
    Bounce batterySwitch(batterySwitchPin, 5);
    Bounce beaconSwitch(beaconSwitchPin, 5);
    Bounce landingSwitch(landingSwitchPin, 5);
    Bounce taxiSwitch(taxiSwitchPin, 5);
    Bounce navSwitch(navSwitchPin, 5);
    Bounce strobeSwitch(strobeSwitchPin, 5);
    Bounce pitotSwitch(pitotSwitchPin, 5);
    int com1SwitchPin = 37;
    int com1State = HIGH; // current state of com1 pin
    int com1Reading; // current reading from com1 input
    int com1Previous = LOW; // previous reading from com1 input
    int com2SwitchPin = 36;
    long time = 0;
    long debounce = 200;
    // Input/Output with simulator
    FlightSimFloat vor1Dataref;
    FlightSimFloat vortwoDataref;
    FlightSimFloat adfDataref;
    // Landing gear handle commands
    FlightSimCommand gearUp;
    FlightSimCommand gearDown;
    // Landing gear actual position
    FlightSimFloat gearDeployLeft;
    FlightSimFloat gearDeployNose;
    FlightSimFloat gearDeployRight;
    // Landing gear handle position
    FlightSimInteger gearHandleDown;
    // Aircraft essential bus voltage
    FlightSimFloat supplyVolts;
    // Avionics switch position
    FlightSimInteger avionicsPowerSwitch;
    FlightSimCommand avionicsPowerOn;
    FlightSimCommand avionicsPowerOff;
    //Flaps switch position
    FlightSimInteger flapsHandle;
    FlightSimCommand flapsUp;
    FlightSimCommand flapsDown;
    // alternator master switch position
    FlightSimInteger alternatorPowerSwitch;
    FlightSimCommand altPowerOn;
    FlightSimCommand altPowerOff;
    // battery master switch position
    FlightSimInteger batteryPowerSwitch;
    FlightSimCommand batteryOn;
    FlightSimCommand batteryOff;
    // fuel pump switch position
    FlightSimInteger fuelpumpPowerSwitch;
    FlightSimCommand fuelPumpOff;
    FlightSimCommand fuelPumpOn;
    // beacon light switch position
    FlightSimInteger beaconPowerSwitch;
    FlightSimCommand beaconOn;
    FlightSimCommand beaconOff;
    // landing light switch position
    FlightSimInteger landingPowerSwitch;
    FlightSimCommand landingOn;
    FlightSimCommand landingOff;
    //taxi light switch position
    FlightSimInteger taxiPowerSwitch;
    FlightSimCommand taxiOn;
    FlightSimCommand taxiOff;
    //nav lights switch position
    FlightSimInteger navlightPowerSwitch;
    FlightSimCommand navlightsOn;
    FlightSimCommand navlightsOff;
    // strobe switch position /////
    FlightSimInteger strobePowerSwitch;
    FlightSimCommand strobeOn;
    FlightSimCommand strobeOff;
    // pitot heat position ////////////
    FlightSimInteger pitotPowerSwitch;
    FlightSimCommand pitotOn;
    FlightSimCommand pitotOff;
    // com 1 audio on/off/////////
    FlightSimInteger com1Audio;
    FlightSimCommand com1Toggle;
    vor1Dataref = XPlaneRef("sim/cockpit2/radios/actuators/nav1_obs_deg_mag_pilot");
    vortwoDataref = XPlaneRef("sim/cockpit2/radios/actuators/nav2_obs_deg_mag_pilot");
    adfDataref = XPlaneRef("sim/cockpit/radios/adf1_cardinal_dir");
    // Input
    pinMode (gearSwitchPin, INPUT_PULLUP);
    pinMode (avionicsSwitchPin, INPUT_PULLUP);
    pinMode (flapsupSwitchPin, INPUT_PULLUP);
    pinMode (flapsdownSwitchPin, INPUT_PULLUP);
    pinMode (alternatorSwitchPin, INPUT_PULLUP);
    pinMode (batterySwitchPin, INPUT_PULLUP);
    pinMode (fuelpumpSwitchPin, INPUT_PULLUP);
    pinMode (beaconSwitchPin, INPUT_PULLUP);
    pinMode (landingSwitchPin, INPUT_PULLUP);
    pinMode (taxiSwitchPin, INPUT_PULLUP);
    pinMode (navSwitchPin, INPUT_PULLUP);
    pinMode (strobeSwitchPin, INPUT_PULLUP);
    pinMode (pitotSwitchPin, INPUT_PULLUP);
    pinMode (com1SwitchPin, INPUT_PULLUP);
    // Output
    pinMode(greenLeftPin, OUTPUT);
    pinMode(greenNosePin, OUTPUT);
    pinMode(greenRightPin, OUTPUT);
    pinMode(redLeftPin, OUTPUT);
    pinMode(redNosePin, OUTPUT);
    pinMode(redRightPin, OUTPUT);
    pinMode (fuelpumpLEDPin, OUTPUT);
    pinMode (beaconLEDPin, OUTPUT);
    pinMode (landingLEDPin, OUTPUT);
    pinMode (taxiLEDPin, OUTPUT);
    pinMode (navLEDPin, OUTPUT);
    pinMode (strobeLEDPin, OUTPUT);
    pinMode (pitotLEDPin, OUTPUT);
    pinMode (com1LEDPin, OUTPUT);
    // X-Plane data Pref
    gearUp = XPlaneRef("sim/flight_controls/landing_gear_up");
    gearDown = XPlaneRef("sim/flight_controls/landing_gear_down");
    gearDeployLeft = XPlaneRef("sim/flightmodel2/gear/deploy_ratio[1]");
    gearDeployNose = XPlaneRef("sim/flightmodel2/gear/deploy_ratio[0]");
    gearDeployRight = XPlaneRef("sim/flightmodel2/gear/deploy_ratio[2]");
    gearHandleDown = XPlaneRef("sim/cockpit2/controls/gear_handle_down");
    supplyVolts = XPlaneRef("sim/cockpit2/electrical/bus_volts[0]");
    avionicsPowerSwitch = XPlaneRef("sim/cockpit2/switches/avionics_power_on");
    avionicsPowerOff = XPlaneRef("sim/systems/avionics_off");
    avionicsPowerOn = XPlaneRef("sim/systems/avionics_on");
    flapsHandle = XPlaneRef("sim/flightmodel2/controls/flap_handle_deploy_ratio");
    flapsDown = XPlaneRef("sim/flight_controls/flaps_down");
    flapsUp = XPlaneRef("sim/flight_controls/flaps_up");
    alternatorPowerSwitch = XPlaneRef("sim/cockpit2/electrical/generator_on[0]");
    altPowerOn = XPlaneRef("sim/electrical/generator_1_on");
    altPowerOff = XPlaneRef("sim/electrical/generator_1_off");
    fuelpumpPowerSwitch = XPlaneRef("sim/cockpit2/engine/actuators/fuel_pump_on");
    fuelPumpOff = XPlaneRef("sim/fuel/fuel_pump_1_off");
    fuelPumpOn = XPlaneRef("sim/fuel/fuel_pump_1_on");
    batteryPowerSwitch = XPlaneRef("sim/cockpit2/electrical/battery_on");
    batteryOn = XPlaneRef("sim/electrical/battery_1_on");
    batteryOff = XPlaneRef("sim/electrical/battery_1_off");
    beaconPowerSwitch = XPlaneRef("sim/cockpit/electrical/beacon_lights_on");
    beaconOn = XPlaneRef("sim/lights/beacon_lights_on");
    beaconOff = XPlaneRef("sim/lights/beacon_lights_off");
    landingPowerSwitch = XPlaneRef ("sim/cockpit/electrical/landing_lights_on");
    landingOn = XPlaneRef ("sim/lights/landing_lights_on");
    landingOff = XPlaneRef("sim/lights/landing_lights_off");
    taxiPowerSwitch = XPlaneRef ("sim/cockpit/electrical/taxi_light_on");
    taxiOn = XPlaneRef ("sim/lights/taxi_lights_on");
    taxiOff = XPlaneRef ("sim/lights/taxi_lights_off");
    navlightPowerSwitch = XPlaneRef("sim/cockpit/electrical/nav_lights_on");
    navlightsOn = XPlaneRef ("sim/lights/nav_lights_on");
    navlightsOff = XPlaneRef ("sim/lights/nav_lights_off");
    strobePowerSwitch = XPlaneRef("sim/cockpit/electrical/strobe_lights_on");
    strobeOn = XPlaneRef("sim/lights/strobe_lights_on");
    strobeOff = XPlaneRef ("sim/lights/strobe_lights_off");
    pitotPowerSwitch = XPlaneRef("sim/cockpit/switches/pitot_heat_on");
    pitotOn = XPlaneRef("sim/ice/pitot_heat0_on");
    pitotOff = XPlaneRef("sim/ice/pitot_heat0_off");
    com1Audio = XPlaneRef("sim/cockpit2/actuators/audio_selection_com1");
    com1Toggle = XPlaneRef("sim/audio_panel/monitor_audio_com1");
    FlightSim.update();
    // divide by 4 to find how many clicks the encoder's been turned
    // (+ve clockwise, -ve anticlockwise, normally)
    short vor1Clicks = (vor1Encoder.read() - vor1EncoderPrevious) / 4;
    // when encoder 'clicks' into a new detent:
    if (vor1Clicks != 0) {
    // change in degrees from current stored value (can be <0 )
    float vor1Change = 0;
    // Threshold between FINE and FAST control: 30ms per click
    if (vor1EncoderClickInterval > 30) {
    // FINE/slow mode. Change by 0.25 degrees per click.
    vor1Change = vor1Clicks * 0.25;
    // FAST/coarse mode. Change by 5 degrees per click.
    vor1Change = vor1Clicks * 5.0;
    // new value = current value plus changes
    float vor1NewValue = vor1Dataref + vor1Change;
    // make sure new value is valid (i.e. when moving across 0deg/360deg)
    while (vor1NewValue < 0.0) vor1NewValue += 360.0;
    while (vor1NewValue >= 360.0) vor1NewValue -= 360.0;
    // write validated new heading back to dataref
    vor1Dataref = vor1NewValue;
    // reset encoder state and interval timer
    // (only when encoder has 'clicked' into a new detent!)
    vor1Encoder.write(0);
    // vortwo code
    short vortwoClicks = (vortwoEncoder.read() - vortwoEncoderPrevious) / 4;
    if (vortwoClicks != 0) {
    float vortwoChange = 0;
    if (vortwoEncoderClickInterval > 30) {
    vortwoChange = vortwoClicks * 0.25;
    vortwoChange = vortwoClicks * 5.0;
    float vortwoNewValue = vortwoDataref + vortwoChange;
    while (vortwoNewValue < 0.0) vortwoNewValue += 360.0;
    while (vortwoNewValue >= 360.0) vortwoNewValue -= 360.0;
    vortwoDataref = vortwoNewValue;
    vortwoEncoder.write(0);
    // adf code
    short adfClicks = (adfEncoder.read() - adfEncoderPrevious) / 4;
    if (adfClicks != 0) {
    float adfChange = 0;
    if (adfEncoderClickInterval > 30) {
    adfChange = adfClicks * 0.25;
    adfChange = adfClicks * 5.0;
    float adfNewValue = adfDataref + adfChange;
    while (adfNewValue < 0.0) adfNewValue += 360.0;
    while (adfNewValue >= 360.0) adfNewValue -= 360.0;
    adfDataref = adfNewValue;
    adfEncoder.write(0);
    // Landing Gear //////
    // Process input
    gearSwitch.update();
    // blocking input on gear handle position
    if(gearSwitch.read() == LOW) { // if the switch is closed
    if (gearHandleDown == 0) { // if gear handle is up
    gearDown.once(); // move it down
    if (gearHandleDown == 1) { // if gear handle is down
    gearUp.once(); // move it up
    } // gearSwitch
    // Process output
    // avionics switches /////////////////////////////////////////////
    avionicsSwitch.update();
    if(avionicsSwitch.read() == HIGH) { // if FUEL PUMP switch is closed
    if (avionicsPowerSwitch == 0) { // if avionics power is up
    avionicsPowerOn.once(); // move it down
    if (avionicsPowerSwitch == 1) { // if handle is down
    avionicsPowerOff.once(); // move it up
    // fuel pump switches ////////////////////////////////////////////
    fuelpumpSwitch.update();
    if(fuelpumpSwitch.read() == HIGH) { // if FUEL PUMP switch is closed
    if (fuelpumpPowerSwitch == 0) { // if avionics power is up
    fuelPumpOn.once(); // move it down
    digitalWrite (fuelpumpLEDPin, 1);
    if (fuelpumpPowerSwitch == 1) { // if handle is down
    fuelPumpOff.once(); // move it up
    digitalWrite (fuelpumpLEDPin, 0);
    // alternator switches /////////////////////////////////////////////////
    altSwitch.update();
    if(altSwitch.read() == LOW) { // if ALTERNATOR switch is closed
    digitalWrite (alternatorPowerSwitch, 0); { // if avionics power is up
    altPowerOn.once(); // move it down
    digitalWrite (alternatorPowerSwitch, 1); { // if handle is down
    altPowerOff.once(); // move it up
    // battery switches /////////////////////////////////////////////////////
    batterySwitch.update();
    if(batterySwitch.read() == LOW) { // if BATTERY switch is closed
    digitalWrite (batteryPowerSwitch, 0); { // if avionics power is up
    batteryOn.once(); // move it down
    digitalWrite (batteryPowerSwitch, 1); { // if handle is down
    batteryOff.once(); // move it up
    // beacon light switches /////////////////////////////////////////////////////////
    beaconSwitch.update();
    if (beaconSwitch.read() == HIGH) { // if beason switch is off
    digitalWrite (beaconPowerSwitch, 1);
    digitalWrite(beaconLEDPin, 1);
    beaconOn.once();
    digitalWrite (beaconPowerSwitch, 0); {
    digitalWrite(beaconLEDPin, 0);
    beaconOff.once();
    // landing light switches //////////////////////////////////////////////////
    landingSwitch.update();
    if (landingSwitch.read() == HIGH) { // if landing switch is off
    digitalWrite (landingPowerSwitch, 1);
    digitalWrite (landingLEDPin, 1);
    landingOn.once();
    digitalWrite (landingPowerSwitch, 0);
    digitalWrite (landingLEDPin, 0);
    landingOff.once();
    // taxi light switches ////////////////////////////////////////////////////////
    taxiSwitch.update();
    if (taxiSwitch.read() == HIGH) { // if landing switch is off
    digitalWrite (taxiPowerSwitch, 1);
    digitalWrite (taxiLEDPin, 1);
    taxiOn.once();
    digitalWrite (taxiPowerSwitch, 0);
    digitalWrite (taxiLEDPin, 0);
    taxiOff.once();
    // flaps switches //////////////////////////////////////////////////////
    flapsupSwitch.update(); flapsdownSwitch.update();
    if (flapsupSwitch.fallingEdge()) {
    flapsDown.once();
    }else if (flapsdownSwitch.fallingEdge()) {
    flapsUp.once();
    // nav light switches /////////////////////////////////////////////////////////
    navSwitch.update();
    if (navSwitch.read() == HIGH) { // if landing switch is off
    digitalWrite (navlightPowerSwitch, 1);
    digitalWrite (navLEDPin, 1);
    navlightsOn.once();
    digitalWrite (navlightPowerSwitch, 0);
    digitalWrite (navLEDPin, 0);
    navlightsOff.once();
    // pitot heat switches ////////////////////////////////////////////////////////
    pitotSwitch.update();
    if (pitotSwitch.read() == HIGH) { // if landing switch is off
    digitalWrite (pitotPowerSwitch, 1);
    digitalWrite (pitotLEDPin, 1);
    pitotOn.once();
    digitalWrite (pitotPowerSwitch, 0);
    digitalWrite (pitotLEDPin, 0);
    pitotOff.once();
    // strobe light switch ////////////////////////////////////////////////////
    strobeSwitch.update();
    if (strobeSwitch.read() == HIGH) { // if landing switch is off
    digitalWrite (strobePowerSwitch, 1);
    digitalWrite (strobeLEDPin, 1);
    strobeOn.once();
    digitalWrite (strobePowerSwitch, 0);
    digitalWrite (strobeLEDPin, 0);
    strobeOff.once();
    Apr 2013
    1,886
    Ok, have not got to the bottom of it yet, but have tweaked the formating and wrapped it in code tags (press the # button when creating a post)
    FlightSim.update();
    // vortwo code
    // adf code
    // Process input
      } // gearSwitch
    // Process output
    altSwitch.update();
      ` digitalWrite (beaconPowerSwitch, 1);
        beaconOn.once();
        beaconOff.once();
        landingOn.once();
      landingOff.once();
        taxiOn.once();
        taxiOff.once();
        flapsDown.once();
        flapsUp.once();
    navSwitch.update();
        navlightsOn.once();
        pitotOn.once();
        pitotOff.once();
      strobeOn.once();
      strobeOff.once();
    } //this one should be here, closes out the ELSE
    }   // none of these should be here
    } //This one should be here, closes loop()
    You have a lot of IF statements that do not close out properly since many of them have a 'if (THIS) do_this {and also do_THAT without a closing }, with all the spare } down at the bottom of the code to make it compile. So many IFs only get checked when previous IFs are also true. Suggest going through the code and using the Arduino curly bracket highlight function to make sure every single IF closes properly, seeing as non of yours should be nested, and that your final one only has a single } after it to close out the loop() function.
    Looking at the code, I think this will just be a case of deleting stray { from places where there is no preceding IF or ELSE.
    For example this line
    Should not have a curly bracket in it
    Also, this looks like you are writing to the inputs which can have interesting effects depending on chip being used. For a classic Arduino this will turn pullups on and off.
    Aug 2019
    2
    Thanks for the advice. Simple oversight. You hit the nail on the head. I have corrected the bracket issue and it works well now.
    Thanks for your help!
