Results 1 to 6 of 6
Thread: VisualTeensy upgraded to support Teensy 4 projects
    Germany
    533
    Here the new release https://github.com/luni64/VisualTeen...s/tag/v0.9.7.0
    New features:
    - T4 compatible (tested compiling only so far, need to wait for my T4...)
    - Colored compiler output
    - Hardware debugging support via (cortex-debug, requires hardware modification!)
    Happy compiling.
    ... and as always: any bug report welcome...
    Here the link to the original VisualTeensy thread.
    2,342
    It seems that it searches Arduino only under C:/program Files etc. but I typically install Arduino in user space (C:-/users/.../...)
    mind to add this search path?
    Germany
    533
    That's true. I'll extend the search range a bit. Might also be good to have a dialog to manually set the Arduino location if it doesn't find one.
    Aug 2016
    131
    good idea, as people with a ssd boot drive typically install things to a HD (I have a ssd boot C: and install things to a hd D
    Germany
    533
    Here a new release which should improve the first startup. It doesn't try to be smart anymore and simply provides a dialog to select an Arduino-folder manually instead.
    https://github.com/luni64/VisualTeensy/releases
    Let me know if this works for you
    2,342
    works for me
    thanks
