Results 1 to 3 of 3
Thread: Arduino UNO WIFI Rev2 with DS18B20 and library OneWire
    Aug 2019
    2
    I use first an Arduino UNO Rev3 with DS18B20, and all works fine with the library oneWire standard.
    I try to change with an Arduino UNO WIFI Rev2, and the DS18B20 is no more detected !
    I try with another Arduino (same model), and I have the same problem.
    I make some mesure with my ascilloscope, and we see the problem (pink line = High level on one output to see when the functions 'begin and search are active, blue line= signal on the DS18B20 command:
    with the Arduino WIFI Rev2, nothing append on the output, I have tried others output with the same result!
    I try with the library OneWireNg, and with this library, it's OK
    I am not good enough to find what must be changed in the standard OneWire.h to correct the problem . After searching, I think the problem is in OneWire_direct_gpio.h (perhaps only a definition to add/change to be compliant with the new architecture of this new card ?)
    CardInfo :
    BN : Arduino Uno Wifi Rev2
    VID : 0x03eb
    PID : 0x2145
    The very simple test program is :
    #include <OneWire.h>
    int DS18S20_Pin = 7;
    int x = 0;
    OneWire ds(DS18S20_Pin);
    byte addr[8];
    void setup(void) {
    delay (500);
    digitalWrite (5, LOW);
    pinMode (5, OUTPUT);
    pinMode (4, INPUT_PULLUP); // pin 4 is connected directly to pin 5 (only for the oscilloscope - pink line)
    digitalWrite (5, HIGH);
    ds.begin (DS18S20_Pin);
    ds.search(addr);
    ds.reset_search();
    Thank in advance for your help
    Jean-Marc
Name:	Arduino UNO Rev3.png
ID:	17237   Click image for larger version.
Name:	Arduino UNO WIFI Rev2.png
    20,573
    Grab the latest OneWire from github.
    Aug 2019
    2
    Thank you for your response,
    With this last library (not referenced in Arduino), it is OK now !
    Jean-Marc
