Hi
I have a problem that drives me crazy, same wiring and code working 100% on Arduino Mega but on Teensy 3.6 one button affects the other once.
I used a 10 K resistor between GND and data pins and 3.3v goes to the other leg of the button, please see the diagram below.
Name:	Screen Shot 2019-08-15 at 19.26.34.jpg
Even when I try to use Internal PULLUP / PULLDOWN resistors it still shows the wrong values for the button pressed.
For Example Pushing Button #0 Gives me the following result:
Name:	Pushing Button Number 0.jpg
Pushing Button #4 Gives me the following result:
Name:	Pushing Button Number 4.png
Again, same schematics and code works fine on Arduino Mega 2560 (the only difference I can think of it's 5v if that relevant)
Your help is much appreciated !
Hardware: Teensy 3.6 (3.3volt)
Software: Arduino IDE v1.8.9
Error Messages: See Above Screenshot of Serial Monitor
Wiring: See Above
* This example demonstrates how to read digital signals
* It assumes there are push buttons with pullup resistors
* connected to the 16 channels of the 74HC4067 mux/demux (in my case 8 buttons)
* For more about the interface of the library go to
* https://github.com/pAIgn10/MUX74HC4067
const int ledPin = 13;
#include "MUX74HC4067.h"
// Creates a MUX74HC4067 instance
// 1st argument is the Arduino PIN to which the EN pin connects
// 2nd-5th arguments are the Arduino PINs to which the S0-S3 pins connect
MUX74HC4067 mux(5, 0, 1, 2, 3);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH); // set the LED on
Serial.begin(9600); // Initializes serial port
// Configures how the SIG pin will be interfaced
// e.g. The SIG pin connects to PIN 3 on the Arduino,
// and PIN 3 is a digital input
mux.signalPin(4, INPUT_PULLUP, DIGITAL);
// Reads the 16 channels and reports on the serial monitor
// if the corresponding push button is pressed
byte data;
for (byte i = 0; i < 8; ++i)
// Reads from channel i and returns HIGH or LOW
data = mux.read(i);
Serial.print("Push button at channel ");
Serial.print(i);
Serial.print(" is ");
if ( data == LOW ) Serial.println("not pressed");
else if ( data == HIGH) Serial.println("pressed");
