Results 1 to 3 of 3
Thread: Teensy 4.0 Reset pin
    Does the Teensy 4.0 have a Reset pin which if pulled low would restart the micro?
    Which pin?
    Thanks in advance.
    9,300
    Teensy 4 does not have a reset pin. closest is :: Grounding the ON/OFF pin for ~5 seconds will remove power then doing that again for half second or so will restart as if reset.
    Thank you @defragster.
