Page 1 of 12 1 2 3 11 ... LastLast
Results 1 to 25 of 276
Thread: RA8875 from Buydisplay
    May 2017
    Netherlands
    121
    Hi all, My projects are running fine with a Teensy 3.6 but for better performance I like to use the Teensy 4, I use a RA8875 display from Buydisplay but when compiling I get a error. What can I do to get my programs to work with the new Teensy.
    Best,
    Johan
    #include <RA8875.h>
    RA8875.cpp:476:11: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment csport = portOutputRegister(digitalPinToPort(_cs));//pinMode(_cs, OUTPUT);
    3,883
    Somebody else asked the same question over in the 1.47 announcement thread. You might want to watch that thread as well in terms of getting an answer:
    May 2017
    Netherlands
    121
    That's a pitty because the RA8875 from Buydisplay are one of the best displays on the market today, in one or other way there is a solution... because I have many projects that are working perfectly on a 3.6 and need more speed ... I hope someone will help.
    Best,
    Johan
    New York
    5,893
    Quote Originally Posted by pd0lew View Post
    Best,
    Johan
    Check what I just posted in thread that @MichaelMeissner referenced: https://forum.pjrc.com/threads/57216...-1-47-Released.
    Cheeers
    May 2017
    Netherlands
    121
    Hi all,
    I changed a bit the RA8875.ccp and the RA8875.h and have no any errors when compiling..... connected my RA display but nothing on the screen. I noticed that the clock on 13 (LED) goes more bright so I think something is working?
    I added the __IMXRT1062__ where is was needed in the .cpp ..... that's solve the errors for the Teensy4 what else can be wrong?
    Best,
    Johan
    New York
    5,893
    @pd0lew
    The version that gets intstalled with Teensyduino does not, work as pointed in the thread that @MichaelMeissner referenced.
    if you look at this post I put together some fixes using Sumotoys development branch that got it working with the T4: https://forum.pjrc.com/threads/57216...l=1#post213253
    May 2017
    Netherlands
    121
    I tested this however without results, the _includes/RA8875_CPU_commons.h is not found.
    Best,
    Johan
    New York
    5,893
    @pd0lew - Johan
    Did you test with the example: benchmarks.ino in the _teensy3/examples. Also did you delete the old library in the teensy library folder and replace it with the new directory in the zip.
    Also, check the wiki for the buydisplay notes: https://github.com/sumotoy/RA8875/wiki
    Hard to help without more details, like the sketch you are using?
    May 2017
    Netherlands
    121
    Perhaps I am looking wrong I dowloaded the stuff from https://github.com/mjs513/RA8875/tree/RA8875_t4 when I look into files examples I also so no benchmarks.ino .
    My test sketch is to simple:
    #include <RA8875.h>
    #define RA8875_RESET 255 //Not used
    #define RA8875_CS 10
    RA8875 tft = RA8875(RA8875_CS, RA8875_RESET, 11, 13, 12);
    void setup(){
    tft.begin(RA8875_800x480);
    tft.fillWindow(RA8875_WHITE);
    7,912
    Are we having an issue compiling or things not showing up on the display?
    The earlier compile issue was probably due to the registers associated with IO pins are 32 bits not 8 bits...
    But assuming that is corrected, I did not have any luck with the RA8875 displays I have from BuyDisplay.com...
    Again might help to know exactly which one you have and how you have it hooked up.
    That is some of them you hook up to +5v as it has it's own VR on it (and one of the jumpers is not set...) On others it does NOT have VR on board and jumper is set and you must supply 3.3v.
    I think I was at times able to get the one without VR to run on a T3.6, but when I tried on T4, I think it pulled too much 3.3v from it and would not run.
    As suggested in the wiki that MJS513 pointed to, you probably need an external power supply to run these.
    Also it recommended making hardware mods (like replace/remove) resistors... SO I punted for now...
    New York
    5,893
    Ok the link you gave me when to the master branch for the library - you need to download this branch: https://github.com/mjs513/RA8875/tree/0.79b11p10
    I just compiled your sketch without a problem and checked the 0.79b11p10 branch and it has the benchmark.ino is in the teensy3 directory. Easiest thing to do is to place the downloaded directory in your Arduino libraries folder and delete the RA8875 folder in the ….\arduino-1.8.9\hardware\teensy\avr\libraries folder
    EDIT: as @KurtE it would also be good to know which display you have buydisplay
    May 2017
    Netherlands
    121
    First I run many displays from Buydisplay 4.3, 5 and 7" runs perfectly with a Teensy 3.6.
    My test display is a RA8875 Buydisplay 4.3 " 800 x 480 pixels.
    Connections CS 10, MOSI 11 an MISO 12 SCK 13, I connected the RA displays many time to the Teensy 3.6 without any issues.
    The supply is 5V (measured 4.98V)
    When there compile errors then there is no need to look to the hardware I suppose.
    Best,
    Johan
    May 2017
    Netherlands
    121
    @mjs513
    A bit desperate.... do you use for sure a RA8875 from Buydisplay?
    In file included from /home/holstein/Arduino/libraries/RA8875-0.79b11p10/RA8875.h:149:0,
    from /home/holstein/Arduino/libraries/RA8875-0.79b11p10/examples/_teensy3/benchmarks/benchmarks.ino:7:
    /home/holstein/Arduino/libraries/RA8875-0.79b11p10/_includes/RA8875_CPU_commons.h:261:3: warning: #warning "Generic Arm detected, not sure if your board it's compatible!" [-Wcpp]
    from /home/holstein/Arduino/libraries/RA8875-0.79b11p10/RA8875.cpp:24:
    /home/holstein/Arduino/libraries/RA8875-0.79b11p10/RA8875.cpp: In member function 'void RA8875::begin(RA8875sizes, uint8_t)':
    /home/holstein/Arduino/libraries/RA8875-0.79b11p10/RA8875.cpp:476:11: error: cannot convert 'volatile uint32_t* {aka volatile long unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
    Error compiling for board Teensy 4.0.
    7,912
    @mjs513 and @pd0lew - I confirmed it does not build...
    Looks like in the last set of changes made to RA87875.h
    There were several #include lines that changed from:
    #include "_settings/xxx"
    to
    #include "_include/xxx"
    I changed all of these lines to _settings and it does build. I do see some warnings about generic... SO not sure if this is right?
    Or maybe new folder (_include) was created but uploaded?
    Kurt
    May 2017
    Netherlands
    121
    I will let you know how I get this to work..... let me make a nice story.
    May 2017
    Netherlands
    121
    Thanks for helping
    Hi all,
    Thanks for helping to get my beautiful RA8875 displays to work with the Teensy 4.
    I am so happy!
    Best regards,
    Johan
    New York
    5,893
    Johan
    Glad you got it working. Be interesting to see what you did to get it working. Whats that little board you have between the display and T4? Level shifter or a tristate buffer or something else?
    Kurt
    Confused on what you changed - in which lib branch. There is _includes directory in the branch. It did compile for me but I don't have a BestBuy display to test with on the Adafruit RA8875 which I did test. Maybe I should pick one up
    May 2017
    Netherlands
    121
    @mjs513,
    The tiny PCB is home made a AD7991 I2C 12 bits works also very nice with the T4.
    @Kurt,
    I included the new library's, it compiles without errors and runs smoothly.
    RA8875-0.79b11p10.zip
    Horiz/Vert Lines 52594
    Rectangles (outline) 265228
    Rectangles (filled) 265744
    Circles (filled) 146734
    Circles (outline) 142973
    Triangles (outline) 18195
    Triangles (filled) 57626
    Rounded rects (outline) 106239
    Rounded rects (filled) 902372
    screen:800x480 - rotation:0
    Benchmark Time (microseconds)
    Screen fill 16493
    Test Pixel 29
    Test Pixels 19419
    Text 3543
    Lines 85975
    Horiz/Vert Lines 52590
    Rectangles (outline) 265374
    Rectangles (filled) 265748
    Circles (filled) 146735
    Circles (outline) 142968
    Triangles (outline) 21212
    Triangles (filled) 60805
    Rounded rects (outline) 106215
    Rounded rects (filled) 902479
    screen:480x800 - rotation:1
    Screen fill 16494
    Test Pixel 29
    Test Pixels 11659
    Text 3544
    Lines 85970
    Horiz/Vert Lines 52595
    Rectangles (outline) 265811
    Rectangles (filled) 265677
    Circles (outline) 142972
    Triangles (filled) 57858
    Rounded rects (outline) 106183
    Rounded rects (filled) 902410
    Best,
    Johan
    New York
    5,893
    @pd0lew
    Did you make any changes to the library?
    May 2017
    Netherlands
    121
    Yes ... a small one : || defined(__IMXRT1062__ on several place .... that's was it.
    New York
    5,893
    Funny - thought I caught all of them.
    7,912
    @mjs513 - There is no _include directory on your github branch: https://github.com/mjs513/RA8875/tree/RA8875_t4
    May 2017
    Netherlands
    121
    Aha there must be changed one line too for the RA8875Usersettings.h this will speedup the thing/
    #if defined(SPI_HAS_TRANSACTION)
    //SPI transaction enabled library----------------------
    #if defined(__MK20DX128__) || defined(__IMXRT1062__) //[Teensy 3.0 , 3.1 , 3.2]
    const static uint32_t MAXSPISPEED = 23000000UL; //don't go higher than 22000000!;
    #elif defined(__MKL26Z64__) //[Teensy LC] (12 or 24 Mhz max)
    const static uint32_t MAXSPISPEED = 12000000UL; //default SPI main speed TeensyLC
    const static uint32_t MAXSPISPEED2 = 22000000UL; //don't go higher than 22000000!;
    #elif defined(___DUESTUFF) //[DUE]
    const static uint32_t MAXSPISPEED = 15000000UL; // try experiment higher values but NOT over 22000000!
    May 2017
    Netherlands
    121
    Bechmark: SPI 23MHz
    Screen fill 16472
    Test Pixel 19
    Test Pixels 12367
    Text 2729
    Lines 82778
    Horiz/Vert Lines 49437
    Rectangles (outline) 264238
    Rectangles (filled) 264507
    Circles (filled) 137937
    Circles (outline) 134157
    Triangles (outline) 20217
    Triangles (filled) 59578
    Rounded rects (outline) 93816
    Rounded rects (filled) 892219
    Screen fill 16473
    Test Pixel 19
    Test Pixels 7392
    Text 2726
    Lines 82886
    Horiz/Vert Lines 49472
    Rectangles (outline) 264586
    Rectangles (filled) 264485
    Circles (filled) 137935
    Circles (outline) 134151
    Triangles (outline) 17231
    Triangles (filled) 56533
    Rounded rects (outline) 93934
    Rounded rects (filled) 892104
    screen:800x480 - rotation:2
    Screen fill 16675
    Test Pixel 18
    Test Pixels 12367
    Text 2720
    Lines 82829
    Horiz/Vert Lines 49440
    Rectangles (outline) 264582
    Rectangles (filled) 264364
    Circles (filled) 137930
    Circles (outline) 134154
    Triangles (outline) 20190
    Triangles (filled) 59713
    Rounded rects (outline) 93865
    Rounded rects (filled) 892278
    May 2017
    Netherlands
    121
