KurtE
Senior Member+
@mjs513 Oops I meant the don't have a writeRect...
And I did figure out that their drawPixels does not work in rotation mode (1 or 3...)
So I put the display back into rotation(0); And then had the display code detect that the image would not fit and then rotated the image while displaying...
I then had the main loop, code use an elapsedMillis object and printed out how long each display took:
So on RA8875:
Note: If I time the ILI9341_t3 version displaying the three same images:
So almost 4 times faster. Yes lots more screen space, but the differences are I do 4 fill rects for the differences...
void drawImage(uint16_t image_width, uint16_t image_height, uint16_t *image, uint16_t bgColor) {
// first lets fill in part of screen that our image does not cover
if ((tft.width() >= image_width) && (tft.height() >= image_height)) {
uint16_t start_x = (tft.width() - image_width) / 2;
uint16_t start_y = (tft.height() - image_height) / 2;
tft.fillRect(0, 0, tft.width(), start_y, bgColor); // top;
tft.fillRect(0, start_y, start_x, image_height, bgColor); // left
tft.fillRect(start_x + image_width, start_y, tft.width() - (start_x + image_width), image_height, bgColor); // right
tft.fillRect(0, start_y + image_height, tft.width(), tft.height() - (start_y + image_height), bgColor); // top;
// now lets draw out each of the lines of the image...
for (uint16_t y = start_y; y < (start_y + image_height); y++) {
tft.setY(y);
tft.drawPixels(image, image_width, start_x, y);
image += image_width;
// We need to rotate the image...
uint16_t start_y = (tft.height() - image_width) / 2;
uint16_t start_x = (tft.width() - image_height) / 2;
//Serial.printf("Rotated: start(%d, %d)\n", start_x, start_y);
tft.fillRect(0, start_y, start_x, image_width, bgColor); // left
tft.fillRect(start_x + image_height, start_y, tft.width() - (start_x + image_height), image_width, bgColor); // right
tft.fillRect(0, start_y + image_width, tft.width(), tft.height() - (start_y + image_width), bgColor); // top;
static uint16_t rotated_row[800]; // max size.
// BUGBUG: need to start at end of row and work back or image inverted
image += (image_width - 1);
for (uint16_t y = start_y; y < (start_y + image_width); y++) {
uint16_t *pimage = image;
for (uint16_t i = 0; i < image_height; i++) {
rotated_row[i] = *pimage;
pimage += image_width;
//Serial.printf("DP %x, %d, %d %d\n", rotated_row, image_height, start_x, y);
tft.drawPixels(rotated_row, image_height, start_x, y);
image--;
So on RA8875:
Display Front of card 176
Display Back of card 175
Display front of chip (DMAMEM?) 176
Display Front of card 49
Display Back of card 49
Display front of chip (DMAMEM?) 49
