Results 1 to 2 of 2
Thread: DMA llibrary
    Jul 2019
    7
    DMA llibrary
    What is the best DMA library which I can use? I want to use Teensy 3.6 to record data from 2-4 simultaneous channels at a sampling rate of 10 kHz for 10 seconds. I want to use DMA to store that data into a buffer. Then use an interrupt to transfer these data to the SD card when the buffer is full. Am I doing it right?
    Thanks in advance for helping!
    Feb 2017
    423
    Have you looked at the DMAChannel class that comes with the Teensy core?
Tags for this Thread
