Results 1 to 4 of 4
Thread: Audio teensy froze during AnalogRead
    Is there some limitation with using the audio tool and analogRead (different pins)?
    My code freezes whenever it reaches that line that has AnalogRead.
    when I remove the audio design objects the code works well.
    Member houtson's Avatar
    Aug 2015
    Scotland
    23
    there shouldn't be a problem, post an example or it is difficult to help. cheers paul
    The bare minimum that presents the problem. I've added a line Serial.print("Works up to here"); to let me know when the program freezes. Moving line below the analogRead will show that it froze at analogread
    #include <avr/wdt.h>
    #include "SerialCom.h"
    #include <RunningAverage.h>
    int centerFreq = 6300;
    double _gain = 1.2;
    unsigned int sampleSize = 24;
    AudioInputAnalogStereo   adcs1;          //xy=200,582
    AudioFilterBiquad        biquad1L;       //xy=400,521
    AudioAmplifier           amp1L;          //xy=542,513
    AudioAnalyzePeak         peakL;          //xy=789,472
    AudioOutputUSB           usb1;           //xy=834.0000114440918,538.0000085830688
    AudioConnection          patchCord1(adcs1, 0, biquad1L, 0);
    AudioConnection          patchCord2(biquad1L, amp1L);
    AudioConnection          patchCord3(amp1L, peakL);
    AudioConnection          patchCord4(amp1L, 0, usb1, 0);
    AudioConnection          patchCord5(amp1L, 0, usb1, 1);
    int monoPeak; //for peak detection
    double mapV = 0.0; //boost voltage
    double afrV = 0.0; //AFR voltage
    double auxV = 0.0; //Aux volt in
    double injectorDuty = 0;
    double low, high;
    int cycles = 10;
    int triggerPin = 3;
    double refVolts = 0.0; //Ref volts
    double revPerSpark = 2.500;
    unsigned long lastTime;
    unsigned long sparkTime;
    volatile double rpm = 0;
    int boostPin = A3;
    const int afrPin = A1;
    const int output5V = A2;
    const int auxPin = A6;
    int timeout = 0;
    int RPMReset = 0;
    const int ledpin = LED_BUILTIN;
    	pinMode(ledpin, OUTPUT);
    	pinMode(3, INPUT_PULLUP);
    	AudioMemory(6);
    	amp1L.gain(_gain);
    	Serial.begin(250000);
    	lastTime = sparkTime = micros();
    // for best effect make your terminal/monitor a minimum of 31 chars wide and as high as you can.
    elapsedMillis fps;
    int settingCheckCounter = 0;
    	//---------READ BOOST---------//
    	mapV = 0; //reset
    	mapV = analogRead(boostPin); //A3 ?voltage divider?
    	mapV = mapDouble(mapV, 0, 1023, 0, 5); //map to reference voltage
    	afrV = analogRead(afrPin);
    	afrV = mapDouble(afrV, 0, 1023, 0.00, 5); //map to reference voltage
    double mapDouble(double x, double in_min, double in_max, double out_min, double out_max)
    	if (x > in_max)
    		x = in_max;
    	if (x < in_min)
    		x = in_min;
    	return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
    void SendDataToPC()
    	Serial.println("Works up to this line");
    2,129
    The audio lib takes over the ADC controllers. you can't mix analogRead with audio ADCs, see warning in Notes sidebar for ADC in audio gui
