Page 2 of 2 FirstFirst 1 2
Results 26 to 30 of 30
Thread: Teensy4 IntervalTimer Channels Problem
  1. #26
    Nov 2018
    Canada
    38
    Quote Originally Posted by alan856 View Post
    @Quadrupel - where did you insert the startup patch in startup.c - that is a VERY busy file - don't want to break it. Also - I'm keeping a copy of the original..
    I stuck it in the resetHandler function.
    Because, I don't like modifying core files, and until there's a production fix to IntervalTimer, I'm putting the fix into the beginning of setup(). It works, and the appropriate comments identify why it's included in the code.
  2. #27
    2,194
    Paul fixed in startup.c of Teensyduino 1.48 beta 1
  3. #28
    Nov 2018
    Canada
    38
    Thanks for the update. I took a look at the change in startup.c. Interesting that it was PIT channel three causing the problem.
    Update: i was looking at a file showing changes only and it didn't show the entire fix. I see the fix is actually your entire recommendation.
  4. #29
    2,194
    There may be an issue with the PIT fix in startup.c for 1.48-beta1, see
    https://forum.pjrc.com/threads/57609...l=1#post216384
  5. #30
    20,567
    Teensyduino 1.48 was been released, with the fix for this problem.
