Results 1 to 3 of 3
Thread: I2C and AD7991 and Teensy4
    May 2017
    Netherlands
    92
    Hi all,
    The Teensy 4...... my questions : the AD7991 works on pins 19 and 18 but not on 17 and 16 any suggestions?
    Best,
    Johan
    3,248
    Quote Originally Posted by pd0lew View Post
    Hi all,
    Best,
    Johan
    The Teensy 4 does not have alternate I2C pins like the previous Teensy LC/3.x microprocessors did. So for the first i2c port, you have to use pins 19 and 18.
    However, the Teensy 4.0 does have a second i2c that are on pins 16 & 17. To use this port, you need to change references from Wire to Wire1 in both your code and in the driver. Typically you would need to clone the driver to have a new name, and change the include file in your .ino/.pde file. Some i2c drivers let you pass in the i2c bus to use as an optional argument.
    As in the previous Teensys when using the alternate i2c pins, pin 17 is the SDA pin and pin 16 is the SCL pin (reversing the order from the standard i2c pins, where pin 19 is SCL and pin 18 is SDA).
    There is a 3rd i2c bus on the Teensy 4.0 that you would need to use the underneath pads to use (pad 24 is SCL2 and pad 25 is SDA2).
    May 2017
    Netherlands
    92
    Thanks Michael that did the job.
    Best regards,
    Johan
