Page 3 of 3 FirstFirst 1 2 3
Results 51 to 61 of 61
Thread: AudioSDR - A single Audio block SDR (software defined radio) processor/demodulator
  1. #51
    Senior Member bmillier's Avatar
    Apr 2016
    Halifax, N.S. Canada
    159
    Hi Frank: Thanks for setting me straight on this. That's how I had remembered things- it was only when I saw another post that I thought differently. Seems like the dedicated ADC (PCM1808) is better than codecs in this regard. I was interested to see you had also used various STM32 MCUs with SDR software. I have a STM32F746 Discovery board which I thought would be great for such projects as it has a beautiful 4.3" capacitive touchscreen and a WM8994 audio codec. I used it for some projects but cannot get the audio line in and audio line out to work simultaneously (microphone in and line out is OK). Others have had the same problem, but I expect someone out there has figured it out.
    I've tried to use the STM32Cube IDE but find it very difficult to get used to, but I've been more successful using the Mbed platform- it's somewhat like the Teensy in good support, libraries etc.
    I just figured out that the Audio library ADCS component has not yet been ported to the T4.x, so my idea of using the internal dual 12-bit ADC is a non-starter.
    Cheers
    Brian
  2. #52
    Jan 2017
    9
    Quote Originally Posted by bmillier View Post
    Cheers
    Brian
    Hi Brian,
    I just came across your post, mentioning the F746 board. I have experimented with this board and have managed get the audio in/out part to work. I am now experimenting with Derek Rowell's AudioDSP library, but the going is slow as the STM32 development environment (as you mentioned) is daunting to say the least. However, I'd be more than pleased to share experiences if you are interested.
    Jan
  3. #53
    Apr 2016
    159
    Hi Jan:
    I gather you are also interested in other MCUs beyond the Teensys. Are you saying that you have gotten line in and line out working simultaneously. That is what I couldn't achieve and there were forum posts saying something about needing a separate I2S channel for line in and line out, and that there was only 1 channel associated with the Codec. Didn't seem to make much sense as the on-board microphone is handled by the codec and mic. in/ line out work together. But, even when I dug into the BSP library code for the codec, I couldn't get both working at once.
    I heard about the AudioDSP, but never looked into it since I couldn't solve the basic line in/line out issue. We are truly spoiled with Teensy as the Audio library is very good. While I'd be hard-pressed to write a DSP lib. function in STM32Cube IDE, I have written several custom ones for the Teensy audio library.
    I'd be interested in hearing how you are progressing. To be honest though, I am only comfortable using the Mbed IDE,I never got comfortable with STM32Cube. Similarly, the Silicon Labs MCUs use an eclipse-based IDE which I found awful to learn, and reverted to Mbed on that MCU as well.
    Cheers
  4. #54
    Jan 2017
    9
    Hi Brian,
    all that steered you away from STM32Cube is valid. It's not only Eclipse that takes getting used to, but the STM32 IDE plugin is very hard to get a handle on and I have found it error prone. The one reason I am not giving up is a very good graphics environment with TouchGFX, but that too is not for the daunted. The "line-in to line-out" audio path can indeed be made to work without an additional I2S channel, but it takes wading through such things as incompatible handler names between the STM32 audio library and the initialization code that CubeMX generates for an F746 discovery board. Explaining 'how to' means dragging you into the STM32 IDE, not where you'd want to go. Maybe one day I'll try Mbed as well, or simply stick to Teensy
  5. #55
    May 2016
    256
    Updates: Hi everybody! I've been involved in a large ESP32 project (a stand-alone WSPR beacon, with 20+ units now deployed) for several months and away from the forum, but still working on AudioSDR, and using it daily. A couple of things:
    1) I have just uploaded an update to GitHub. It includes a bugfix for the AM demodulator that caused severe audio distortion, and changes to the PLL for the SAM demodulator to improve the carrier lock. I also removed the EXAMPLES folder, which should never have been there Link here
    2) The SDR works well on the T4.1. I continue to work on the UI, and the rf preprocessor. Here is an image of the ILI9341 2.8" display with spectrum and signal strength:
    The yellow stripe on the spectrum shows the tuning band. I have struggled to develop a waterfall display, with no satisfactory solution.
    A second screen shot shows an example of my encoder-based menu system for selecting/changing system parameters.
    (I find that the touch screen is just too hard to use for small menu buttons)
    I have not published the whole system code because of the dependencies on my homebrew receiver rf front end, and the structure of the user interface (encoders, pots, tactile push buttons etc). However, if anybody wants the whole package just let me know by PM with your email, and I'll send you a zip with the whole bundle. You'll be on your own to work out what's going on
    I am currently working on adding a transmitter to make a complete transceiver. I have the Teensy based DSP audio processing (compression, shaping, Hilbert transfom (phase-shifter)) done, and am now working on the hardware RF mixers and amplifiers. It's stand-alone right now but the goal is to make it a fully integrated transceiver.
  6. #56
    Apr 2020
    Guelph Ontario Canada
    116
    Hi Derek, thanks for updating your SDR library ..There are members on my Facebook Group (Keiths_SDR) that are using it for their receiver builds ..Im also running the 2.8" touch panel as well as the ili9488 3.5" touch panel ..and I agree the 2.8" is just a touch undersized for touch ..
    Cheers
    K
  7. #57
    May 2016
    256
    Another quick GitHub update: Just to let you know that I"ve just uploaded another update with minor changes:
    1. A more recent version of the manual (with source code for BareBonesWSPR)
    2. An EXTRAS folder with the .ino for BareBonesWSPR, and a copy of my library SI5351quad, which generates quadrature outputs directly on channels 0 and 1 of the SI5351A oscillator, without generating an x4 frequency and using a Johnson counter to create the quadrature pair.
  8. #58
    Apr 2021
    Ladrboke UK
    2
    Any chance of TX?
  9. #59
    May 2016
    256
    Quote Originally Posted by AntonyWatts View Post
    Any chance of TX?
    Yes... I'm working on it! Right now I have the SDR part (Audio processing, IQ generation etc) working in a stand-aloe config, and am concentrating of the RF hardware side (mixers. QRP linear amplifier, filters). The goal is to integrate the RX and TX after both are working,
    Derek, AK1WI
  10. #60
    Apr 2021
    Ladrboke UK
    2
    One more thing
    Derek, AK1WI
    I am working to get your RX version working, but I am on a MacBook. You only have instructions of how to load the arm...h files on a PC, do you have info how / where to copy them to on a Mac?
    Front end here is either a QCX+ or an Elektor SDR board, IQ outputs. Hope this will work! Eventually I hope to follow you and get a TX/RX going, simple OLED display, nothing fancy... Activity on GanymedeHam.blogspot.com
  11. #61
    May 2016
    256
    Sorry, I don't have any real experience with a Mac. Since it is just a matter of substituting files in the Teensy folders, can you find the appropriate place on the Mac?
