Results 1 to 2 of 2
Thread: SPI in 32 bit data TX
    is there a way to configure the SPI to send 32bits without braking it up?
    // set pin 10 as the slave select for the digital pot:
    const int slaveSelectPin = 10;
    long DATA =0;
    // set the slaveSelectPin as an output:
    pinMode (slaveSelectPin, OUTPUT);
    digitalWrite (slaveSelectPin, HIGH);
    // initialize SPI:
    SPI.begin();
    SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0));
    delay(1);
    digitalWrite(slaveSelectPin,LOW);
    SPI.transfer(DATA);
    SPI.transfer(DATA);
    SPI.transfer(DATA);
    SPI.transfer(DATA);
    digitalWrite(slaveSelectPin,HIGH);
    Feb 2014
    Colmar, France
    2,537
    The answer is no, at least for the Teensy 3.x. The SPI transmit data register can hold a maximum of 16bit. But there is a configuration flag for continuous mode, so that you can transmit your 32bit value as 2x16bit with (almost) no gap.
    But if I remember well, neither 16bit nor continuous mode are supported by the standard (Arduino compatible) SPI library. Either you find an optimized library for the T3.x or you implement these yourself after studying the SPI chapter of the processor reference manual.
