Results 1 to 11 of 11
Thread: Teensy4.0 Serialmonitor in Arduino IDE
    Jul 2019
    5
    Hello.
    I've just got my Teensy4.0 and done some testing-
    Now i have this little problem:
    I'm using Arduino IDE 1.8.9. I did upload a simple sketch, LED blink with serial read out.
    But i don't get any text in the serial monitor.
    I have tried with COMport setting: Port 3. Windowbar shows: TeensyMonitor COM3 Online.
    Also: COMport 3 Serial (Teensy4.0). Window bar shows: COM3 (Teensy) Serial.
    I also tried with several different baudrates(9600, 19200, 38400, 115200).
    unsigned long prevTime = 0;
    const long interval = 2000;
    int state = LOW;
      Serial.println("TEST Analog");
      pinMode(out, OUTPUT);
      digitalWrite(out, LOW);
      //Serial.println("TEST 1");
    //   put your main code here, to run repeatedly:
      unsigned long curTime = millis();
      if (curTime - prevTime >= interval) {
        prevTime = millis();
        if (state == LOW) {
          state = HIGH;
          state = LOW;
        Serial.print("state ");
        Serial.println(state);
        digitalWrite(out, state);
    So do is there someone that can tell my how to get serial monitor to work?
    In advance, thank you.
    you might need to use latest teensyduino,
    also, there are some ongoing improvements to the serial monitor. i think discussion is in 4.0 beta thread.
    Jul 2019
    5
    Thanks.
    I have the latest Teensyduino as i download it yesterday.
    Maybe i'll just have to wait for some new release.
    take a look at this thread that discusses some serial monitor issues and a few fixes.
    https://forum.pjrc.com/threads/54711...l=1#post213526
    1,171
    When I added this statement to your code:
    const uint8_t out = LED_BUILTIN;
    it works. Teensy 4(beta 2) with current Arduino and Teensyduino on Windows 10.
    Pete
    Jul 2019
    5
    I don't know why, but there no change....
    1,171
    Does it toggle the LED every two seconds?
    Pete
    20,761
    Indeed, as Pete said, your program doesn't compile. I added that line and it's working here on a Teensy 4.0. Here's a screenshot of the serial monitor with it running.
    Here is a complete copy of the working code:
    int state = LOW;
        if (state == LOW) {
          state = HIGH;
          state = LOW;
    Oct 2012
    Portland OR
    677
    The original code not compiling seems like a clue that the code running on the OP's T4 is not what is listed; possibly it is still the original blink sketch?
    Jul 2019
    5
    Yes it do.
    I also had another sketch and that's working to except from the serial readout.
    Jul 2019
    5
    No its not the original blink sketch.
    I can change the interval and it changes to.
    i have been running at least different 3 different sketches.
    So it is compiling and uploading the sketch.
    I have also tried the "Serial" from "examples - teensy" and there is no readout in the serial monitor.
