Arduino: 1.8.9 (Windows 10), TD: 1.47-beta7, Board: "Teensy 4.0, Serial, Faster, US English"
speeduino: In function 'void loop()':
speeduino:429: warning: unused variable 'ignition7StartAngle'
int ignition7StartAngle = 0;
speeduino:432: warning: unused variable 'ignition8StartAngle'
int ignition8StartAngle = 0;
utils: In function 'uint32_t calculateCRC32(byte)':
utils:69: error: no matching function for call to 'FastCRC32::crc32(byte*, int, bool)'
CRC32_val = CRC32.crc32(&raw_value, 1, false);
In file included from C:\Users\D\Desktop\speeduino\speeduino\utils.ino:12:0:
C:\Users\D\AppData\Local\Temp\arduino_build_731221\sketch\src/FastCRC/FastCRC.h:167:12: note: candidate: uint32_t FastCRC32::crc32(const uint8_t*, uint16_t)
uint32_t crc32(const uint8_t *data, const uint16_t datalen); // Alias CRC-32/ADCCP, PKZIP, Ethernet, 802.3
C:\Users\D\AppData\Local\Temp\arduino_build_731221\sketch\src/FastCRC/FastCRC.h:167:12: note: candidate expects 2 arguments, 3 provided
utils:74: error: no matching function for call to 'FastCRC32::crc32_upd(byte*, int, bool)'
CRC32_val = CRC32.crc32_upd(&raw_value, 1, false);
C:\Users\D\AppData\Local\Temp\arduino_build_731221\sketch\src/FastCRC/FastCRC.h:170:12: note: candidate: uint32_t FastCRC32::crc32_upd(const uint8_t*, uint16_t)
uint32_t crc32_upd(const uint8_t *data, uint16_t len); // Call for subsequent calculations with previous seed
C:\Users\D\AppData\Local\Temp\arduino_build_731221\sketch\src/FastCRC/FastCRC.h:170:12: note: candidate expects 2 arguments, 3 provided
utils:89: error: no matching function for call to 'FastCRC32::crc32(byte*, int, bool)'
utils:93: error: no matching function for call to 'FastCRC32::crc32_upd(byte*, int, bool)'
utils:108: error: no matching function for call to 'FastCRC32::crc32(byte*, int, bool)'
utils:112: error: no matching function for call to 'FastCRC32::crc32_upd(byte*, int, bool)'
utils:127: error: no matching function for call to 'FastCRC32::crc32(byte*, int, bool)'
utils:131: error: no matching function for call to 'FastCRC32::crc32_upd(byte*, int, bool)'
utils:140: error: no matching function for call to 'FastCRC32::crc32(byte*, int, bool)'
utils:144: error: no matching function for call to 'FastCRC32::crc32_upd(byte*, int, bool)'
utils:165: error: no matching function for call to 'FastCRC32::crc32(byte*, int, bool)'
utils:170: error: no matching function for call to 'FastCRC32::crc32_upd(byte*, int, bool)'
