Results 1 to 3 of 3
Thread: Addressable LED HD107S
    Member dimitre's Avatar
    Aug 2016
    São Paulo
    75
    I've been testing the new chip HD107S which seems to address most of the issues descibed in APA102 in this compreensive Paul's analysis
    https://www.pjrc.com/why-apa102-leds...ble-at-24-mhz/
    I've made some tests and it seems the PWM rate is very high (supplies says it it is +26kHz)
    it handles data transfer up to 40MHz (I didnt test it yet)
    It seems to have built in sleep, very low power consumption when no data is received, and seems to handle better power consumption over the entire strip.
    I'll be trying it in a cinema studio to see if the PWM helps a lot with camera frequencies.
    Anybody else is trying this kind of strip?
    I have some samples of NS107S LEDs, untested so far. Maybe same as yours but a different manufacturer? Maybe a clone?
    Aug 2016
    São Paulo
    75
    I hear this is the same chip, only Newstar brand use NS as a prefix
