Results 1 to 9 of 9
Thread: Teensy 4 : Sketch does not run unless Serial Monitor is open
    I compiled a sketch and it is running fine.
    I then close the Arduino IDE and disconnect power to the Teensy 4 (It is powered via Vin).
    When I reconnect power to the board, nothing happens until I reopen the Arduino IDE AND start the Serial Monitor.
    What may be causing this?
    Thanks in advance for the community's help.
    10,409
    Posting the sketch would allow a good answer … a good guess is that there is something like :: while (!Serial); in setup that won't pass until the Serial Monitor connects.
    Thank you @defragster. I appreciate your prompt help to this frustrating problem.
    Here is my code. BTW, when USB cable is connected, the board does pull an IP Address.
      delay(2000);
      Serial.println("Starting ...");
      //https://www.pjrc.com/store/wiz820_sd_adaptor.html#init
      //https://github.com/PaulStoffregen/Ethernet
      pinMode(9, OUTPUT);
      digitalWrite(9, LOW);    // begin reset the WIZ820io
      pinMode(10, OUTPUT);
      digitalWrite(10, HIGH);  // de-select WIZ820io
      pinMode(4, OUTPUT);
      digitalWrite(4, HIGH);   // de-select the SD Card
      digitalWrite(9, HIGH);   // end reset pulse
      Serial1.addStorageForRead(buf1, sizeof(buf1));
      Serial2.addStorageForRead(buf2, sizeof(buf2));
      Serial3.addStorageForRead(buf3, sizeof(buf3));
      for (int i = 0; i < 2; i++)      // for (int i = 0; i < 3; i++)
        leddar[i].init();
        sumTime[i] = 0;
      Serial.println("Ethernet WebServer Example");
      Ethernet.begin(mac, ip);
      if (Ethernet.hardwareStatus() == EthernetNoHardware) {
        Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
        while (true) {
          delay(1); // do nothing, no point running without Ethernet hardware
      if (Ethernet.linkStatus() == LinkOFF) {
        //Serial.println("Ethernet cable is not connected.");   //not working?
      server.begin();
      Serial.print("server is at ");
      Serial.println(Ethernet.localIP());
      Serial.print("Initializing SD card...");
      if (!SD.begin(chipSelect)) {
        Serial.println("initialization failed!");
        //return;
      Serial.println("initialization done.");
      write2SD();
      readSD();
      u8g2.begin();
      u8g2_prepare();
      String myVal = "jimmie";
      showU8G2(11, 12, myVal);
      delay(2000);
      Serial.println("------------->>>>  Starting");
    10,409
    That is just code for setup() , not a complete sketch - the typical problem is the noted while(!Serial) which doesn't show there.
    It may be that one of the .init()/.begin() functions stops to wait for !Serial to exist?
    Without the Serial Monitor printing it will be hard to say where it stops without adding blink output to LED_BUILTIN (#13) or to a UART or something for an indication of where the code stops to figure out why.
    Thank you @defragster. Your input helped me debug further.
    You were right about the culprit.
    I found out that the library I am using has the Leonardo while (!Serial)
    Thanks again.
    Oct 2012
    Portland OR
    677
    Your setup code includes: "Serial.println("Starting ...");" which uses the Teensy USB-serial device. Currently on T4 I believe if you send any characters to the USB-Serial device (using Serial.X instead of Serial1.X etc for a real UART) then the serial interrupt system is disabled until the USB endpoint is accessed and the data is read out by the USB host PC. I'm not sure it is supposed to work that way, I don't think other Teensy models do that; but apparently for now, it does work that way. This was reported here: https://forum.pjrc.com/threads/57325...l=1#post214149
    Thank you JBeale.
    The culprit was the
    while(!Serial)
    statement in the library I was using.
    The only problem remaining now is the SD behavior on the T4 .... :-).
    10,409
    This isn't a case of Serial.available not incrementing. I ran a sample and that problem is real - but that is reading input - which works - just not having .available() be reliable yet.
    Teensy 4 is perfectly good starting up and printing when Serial is not online so as found the problem was the embedded " while (!Serial) " This have been working well through T4 Beta period.
    Oct 2012
    Portland OR
    677
    Thanks for that correction defragster, I did misinterpret the problem. I would correct or delete my earlier post but the forum no longer seems to allow that.
