Results 1 to 2 of 2
Thread: Animated GIF from SD Card Teensy 3.6 OctoWS2811
    Aug 2019
    4
    Hi
    I am sure this may have been covered, but I cant find a definitive answer
    I'd like to run animated GIFs on my 32x32 WS2812b panel from the SD card on a Teensy 3.6 with the OctoWS2811 board.
    All the tutorials/post I've found either use Glediator/Jinx or a Smartmatrix board which is designed for HUB75 panels.
    I have had Gled/Jinx running just fine, but I want it to stand alone.
    If it will run Gled/Jinx show files in a standalone mode, that would be a bonus, but not a necessity.
    The AnimatedGIFs example in SmartMatrix can be modified easily to remove all references to SmartMatrix Library and drive another display
