Results 1 to 5 of 5
Thread: A simple little t4 pc
    Aug 2017
    127
    @All
    I thought I share this. It is a simple PC that started out the T36 and now I've ported most of it to the T4B2. When the breakout board is available from Tindie I will be able to finish porting it to the T4.
    Here are a few pictures. I do not have a very good camera or the ability to do a video so pictures are not that good.
ID:	17461 Click image for larger version.
    This is the whole system on the left and the boot up screen on the right. You will see the older T36 breadboard in the upper left. The T4 is running a 10.1" TFT form Buydisplay that is using the RA8876 display controller fro RAIO. A wireless keyboard and mouse are connected along with USB to SATA adapter for the hard drive through a Belkin 4 port HUB.
    At this point I have three main programs loaded into the T4. A file manager, WIP of course, STBASIC which needs the modified version of the KILO text editor.
    File Manager mouse capable with dialog boxes and message boxes:
ID:	17463 Click image for larger version.
ID:	17465 Click image for larger version.
    Kilo text file editor:
ID:	17467 Click image for larger version.
    STBASIC showing the use of user defined fonts on the RA8876:
    STBASIC is a structured BASIC interpreter without the use of line numbers so that was the need for the KILO editor which available on the internet.
    It is easy to add commands and functions so a lot of the the library functions can be implemented in basic which I have done.
    There are many things I have yet to setup that were on the T36, touchscreen, WIFI with the ESP8266 and sound.
    These Teensy's are so awesome. Thanks Paul and all others contributing to this forum.
    4,108
    @wwatson - real nice - looks like fun to play with
    9,742
    Good work.
    May 2015
    San Francisco
    159
    Very nice indeed! Will you be publishing the source code?
    Aug 2017
    127
    Quote Originally Posted by blackketter View Post
    At this point it very much WIP. I have all of the software components except for MSC in one sketch folder. I want make separate libraries of the RA8876 drivers which are my version of Ra8876_lite and TFT. TFT.cpp contains many wrapper functions for Ra8876_lite. Then there is STBasic which will be a separate library and FM (File Manager) in a separate library as well. I think dialog.cpp should be part of the Ra8876_lite library. Right now I am only using the dialog popups for the File Manager.
    I will probably start with Ra8876_lite getting it into a library first.
    Lots of work to do yet.
