Results 1 to 4 of 4
Thread: ILI9341 with XPT2046_Touchscreen
    I received three new ILI9341 Displays from PJRC. The screen displays the same graphics buttons as the older ILI9341 units. However, the touch screen appears to have X/Y indexing that is a mirror image of the original using the same touch code. In other words touch buttons displayed on lower right are activated in a different location on the screen. Has the indexing been changed on the newer panels? Has anyone experienced this same issue?
    9,299
    Possible the assembly or setup changed.
    Try a call to :: setRotation(uint8_t n) { rotation = n % 4; }
    Find the rotation that syncs with display rotation.
    5,278
    Or simply you need to do a new calibration for the display touch and change the mappings.
    As for the question of if PJRC received a new batch of these which are different... Not sure.
    Dec 2013
    223
    defragster
    I also had this issue before
    From the Arduino Software (IDE) toolbar menu: File > Examples > XPT2046_Touchscreen > ILI9341Test
    in setup()
    tft.setRotation(1); // Screen rotation 1~4
    ts.setRotation(1); // Touch rotation 1~4
    #include <ILI9341_t3.h>
    #include <font_Arial.h> // from ILI9341_t3
    #include <XPT2046_Touchscreen.h>
    #define CS_PIN  8
    #define TFT_DC  9
    #define TFT_CS 10
    // MOSI=11, MISO=12, SCK=13
    XPT2046_Touchscreen ts(CS_PIN);
    #define TIRQ_PIN  2
    //XPT2046_Touchscreen ts(CS_PIN);  // Param 2 - NULL - No interrupts
    //XPT2046_Touchscreen ts(CS_PIN, 255);  // Param 2 - 255 - No interrupts
    //XPT2046_Touchscreen ts(CS_PIN, TIRQ_PIN);  // Param 2 - Touch IRQ Pin - interrupt enabled polling
      Serial.begin(38400);
      tft.begin();
      tft.setRotation(1);
      ts.begin();
      ts.setRotation(1);
      while (!Serial && (millis() <= 1000));
    boolean wastouched = true;
      boolean istouched = ts.touched();
      if (istouched) {
        TS_Point p = ts.getPoint();
        if (!wastouched) {
          tft.setTextColor(ILI9341_YELLOW);
          tft.setFont(Arial_60);
          tft.setCursor(60, 80);
          tft.print("Touch");
        tft.fillRect(100, 150, 140, 60, ILI9341_BLACK);
        tft.setTextColor(ILI9341_GREEN);
        tft.setFont(Arial_24);
        tft.setCursor(100, 150);
        tft.print("X = ");
        tft.print(p.x);
        tft.setCursor(100, 180);
        tft.print("Y = ");
        tft.print(p.y);
        Serial.print(", x = ");
        Serial.print(p.x);
        Serial.print(", y = ");
        Serial.println(p.y);
        if (wastouched) {
          tft.setTextColor(ILI9341_RED);
          tft.setFont(Arial_48);
          tft.setCursor(120, 50);
          tft.print("No");
          tft.setCursor(80, 120);
          tft.print("Touch");
        Serial.println("no touch");
      wastouched = istouched;
