Results 1 to 5 of 5
Thread: Midi + Solenoid
    Midi + Solenoid
    Hello guys,
    I have a quite simple project but I can't find any clear information / help about it.
    I'll try to explain it simple :
    - I want to trigger 12 soleno´ds according to a midi sequence with Ableton Live. For exemple the Soleno1 is the A1 note, the Soleno2 is the A1# note etc.
    The idea is to create a drum box with solenoids triggered with midi notes.
    I think it's possible with a Teensy ?
    Thanks a lot
    F
    Sep 2014
    South Dundas, Ontario, Canada
    41
    Yes, a Teensy can do it.
    Have a look here; https://learn.adafruit.com/midi-sole...ummer/overview
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,219
    I think this link covers stepping up the voltage.
    https://www.electronics-tutorials.ws...or/tran_4.html
    thanks a lot ! I just found this project, that is perfect for me I think https://www.instructables.com/id/Aut...IDI-Xylophone/
    Sep 2014
    41
    Ok, that project/link can help you. The link uses an UNO but you could also use a Teensy but the pin numbers may be different. I haven't used my Teensy yet thus can't guide you in substituting the UNO with a Teensy.
