Midi + Solenoid
musiquemeuble
Hello guys,
I have a quite simple project but I can't find any clear information / help about it.
I'll try to explain it simple :
- I want to trigger 12 solenoïds according to a midi sequence with Ableton Live. For exemple the Soleno1 is the A1 note, the Soleno2 is the A1# note etc.
The idea is to create a drum box with solenoids triggered with midi notes.
I think it's possible with a Teensy ?
Thanks a lot
F
Ok, that project/link can help you. The link uses an UNO but you could also use a Teensy but the pin numbers may be different. I haven't used my Teensy yet thus can't guide you in substituting the UNO with a Teensy.
