Results 1 to 4 of 4
Thread: Memory map for i.MX RT1062
    Aug 2019
    4
    I'm new to micro controllers and diving in to learning about registers but I can't find any info about this chip. The data sheet from NXP doesn't have the layout of the registers. For example, here's a screen shot from a tutorial about how the registers are assigned on an Atmega chip from an Arduino. I don't own an Arduino so was hoping I could explore this on my new Teensy. Anyone have a link to this?
Name:	atmega register map.PNG
    9,711
    For some idea of memory mapping check this thread :: T4-0-Memory-trying-to-make-sense-of-the-different-regions
    There is an installed file with linker details :: ...\hardware\teensy\avr\cores\teensy4\imxrt1062.ld
    On above thread is imxrt-size source code for an executable to add to building that shows the allocation in the final HEX.
    And this file has a few thousand lines of the register addresses and values as #define pulled out of the 3.5+K Refman :: ...\hardware\teensy\avr\cores\teensy4\imxrt.h
    There are some comments and the indicative names that AFAIK match the names in the RM - though not sure the page numbers in some comments aren't from earlier version of the manual since updated.
    5,423
    At some point, would be great to take a pass through the source files and verify and if necessary update all of the comments to reference the section number (and/or page numbers) to be to the current IMXRT 1062 reference PDF. I believe a lot of them still reference the first version of the 1052 reference PDF.
    Aug 2019
    4
    Thanks for the reference. Curious that NXP doesn't provide the same level of detail for the registry summary as does Microchip for their ATmega328 chips. I guess at the end of the day the graphic format is less important than the actual register and pin ID so I'm sure I can get through it one way or the other.
