Results 1 to 2 of 2
Thread: Teensy 4.0 power button
    Sep 2019
    3
    Can someone tell me what the proper connection is for the power pushbutton on the 4.0? I assume it is a normally open with a connect to ground when closed, but I can't actually find anywhere this is documented, and I hate assuming....
    9,770
    There are notes around … I know I typed most of this recently ...
    > left open the Power pin is held 3V+.
    > when T4 running 'ON' : and Power pin is grounded for about 5 seconds the T4 goes OFF and the 3.3V regulator is turned off
    > when T4 'OFF' but given VIN: and Power pin is grounded for about 0.5 second the T4 goes ON and Teensy 4 turns ON and begins fresh through setup()
    > If the RTC** battery is connected the On/Off state can be changed as above even when not VIN powered
    > If the RTC** battery is connected the On/Off state persists across removing VIN power
    > With NO RTC battery connected and no VIN, the On/Off state reverts to ON given VIN power
    > ** when 'some' amount of external power is presented to the T4 GPIO when OFF - like UARTS at 3+V on multiple I/O pins - it feeds power to the RTC system as if a battery were connected
