Results 1 to 4 of 4
Thread: Baud Rate for IDE Serial Monitor
    Mar 2015
    UK
    301
    Am I correct in thinking that setting the Baud Rate for the Teensy port to the Arduino IDE Serial Monitor (e.g. "Serial.begin(115200);") over the mini USB is rather academic?
    I wrote my own Serial Monitor yesterday to run on a Win7 host PC using Delphi/Pascal because I wanted to log data direct to a Hard Drive text file. The Commport component available to me was very old and the highest speed in its own Baud Rate setting was 38400. So I was a bit surprised when it actually worked fine.
    It set me wondering. If I'm using virtual comm ports under Win7, then what relevance is the selected speed for Teensy code? The USB interface is sending USB packets back and forth in any case, and that's more likely to be at 480 Mbits/sec rather than any slow baud rate.
    Or will the Teensy actually slow down transmission if I set, say, "Serial.begin(9600);" ?
    9,915
    That baud is only used when talking to an FTDI thing that interfaces USB to MCU Serial on the other end - it passes that to set the serial interface baud on that chip.
    When going USB to a Teensy USB device it runs at the native Teensy USB speed 12 or 480 Mbps
    540
    In case you are interested: here is the definition of Serial.begin... Useful if you want your code to be compatible to legacy boards, but if you code for a Teensy it is rather pointless to call it :-)
    class usb_serial_class : public Stream
    public:
    	constexpr usb_serial_class() {}
            void begin(long) {
    		//uint32_t millis_begin = systick_millis_count;
    		//disabled for now - causes more trouble than it solves?
    		//while (!(*this)) {
    			// wait up to 2.5 seconds for Arduino Serial Monitor
    			// Yes, this is a long time, but some Windows systems open
    			// the port very slowly.  This wait allows programs for
    			// Arduino Uno to "just work" (without forcing a reboot when
    			// the port is opened), and when no PC is connected the user's
    			// sketch still gets to run normally after this wait time.
    			//if ((uint32_t)(systick_millis_count - millis_begin) > 2500) break;
    20,674
    The number you use in Serial.begin(baud) is completely ignored.
    The baud rate setting on the PC side is also not used for the USB communication speed. But it is communicated to Teensy, so your code can read it with Serial.baud(). That's useful if you want to relay the communication to a real hardware serial port and you want Teensy to automatically use the PC's baud rate setting on that real serial port.
