turbochris
New member
I'm adding adressable LED to my almost famous turbine powered minivan. I installed a larger alternator, a 2000 watt AC inverter and plan on using 110 vac to 5, 12, 30, 36 vdc depending on what LEDS I use. The power supplies will be close to the point of load.
We're using a teesny 3.2 and an octows2811 now, from what I'm reading so far, the pinout on the octows2811 is incompatible with the teensy 4.0. Has anyone come up with a simple work around?
https://github.com/FastLED/FastLED/wiki/Parallel-Output
